JDM vs USDM ITR
Old Jan 31, 2009 | 12:14 PM
wtfmike's Avatar
Default JDM vs USDM ITR
Is there a way to tell the JDM ITR apart from the USDM ITR while just looking at them? I'm going to look at a 2000 ls That the owner says has the JDM ITR motor. Thanks.
Old Jan 31, 2009 | 12:24 PM
VTECROAR96typeR's Avatar
Default Re: JDM vs USDM ITR
you must be new at this correct?
Old Jan 31, 2009 | 12:29 PM
wtfmike's Avatar
Yes.
Old Jan 31, 2009 | 12:34 PM
thabao's Avatar
look at the engine stamp
JDM= B18c
USDM= b18c5
Old Jan 31, 2009 | 12:37 PM
wtfmike's Avatar
Thanks one more question. Do they both have the s80 tranny?
Old Jan 31, 2009 | 12:41 PM
BlueIntegraBoy's Avatar
http://www.ff-squad.com/tech/temp/Bgears.htm
JV Honda Si's Avatar
JDM ITR is stamed b18c on block were the US ITR is b18c5 and the head has PR3 stamed on both. this is one way so good luck.
Old Jan 31, 2009 | 12:42 PM
wtfmike's Avatar
Is this correct. The usdm itr tranny is the s80 and the jdm one is j4d or n3e.
Old Jan 31, 2009 | 01:18 PM
i belive 4jhd = 4.4 final drive offered as original equipment, while ne3 = 4.78 final drive original equipment. check for the trany brace as well.
Old Jan 31, 2009 | 02:22 PM
JReal's Avatar
b18c could be a jdm gsr too, so be careful.
Old Jan 31, 2009 | 03:24 PM
LateNyta's Avatar
oh ****, fack me
Old Jan 31, 2009 | 03:51 PM
dumafit's Avatar
but if it's a stock GSR, it'll have the black valve cover and the ugly intake manifold
but those two can be easily swapped out by the previous owner for a blox/skunk2 style intake manifold
check the transmission for LSD also
edit: if it's a stock 98spec jdm itr b18c, it'll have the jdm 4-1 header also
here's a pic of my 98spec jdm itr b18c, but i swapped out the header for a rage race header
Old Jan 31, 2009 | 04:33 PM
Devon M's Avatar
Also if he doesn't have papers on the engine then I wouldn't buy it.
Old Jan 31, 2009 | 05:31 PM
Deetz's Avatar
Crazy Honda Guy
Some differences off the op of my head:
- Red valve cover has the "H" symbol on it, usdm doesn't
- engine will have a PR3 head, and block will be stamped B18C only
- jdm engine has higher compression at 11:1, usdm is 10.6:1
- tranny has 4.7 final drive
- header is a tubular design with 2.5" collector
Old Feb 2, 2009 | 08:51 AM
HYREV2NR's Avatar
Originally Posted by BlueIntegraBoy
Thanks for posting this link. I always like saving info like this for future reference.
magicguy
Mar 6, 2010 12:53 PM
Stillo
Sep 27, 2006 09:33 PM
90teg
Aug 25, 2005 07:46 PM
Nameless RB26
Mar 20, 2003 06:32 PM
