Brake swapping
Old Jan 31, 2009 | 11:46 AM
xXViperXx's Avatar
Default Brake swapping
92 civic lx
00 si front and rear disc
i have the proportioning valve for the SI, the brake booster, all four knuckles, and the rear trailing arms
the knuckles swap over just fine. what about the booster and the proportioning valve? Do i need them?
Any ideas?
Old Jan 31, 2009 | 12:58 PM
94EG8's Avatar
Seagull Management
Default Re: Brake swapping
Originally Posted by xXViperXx
92 civic lx
Any ideas?
Use a '90 - '93 non ABS integra proportioning valve (the '99 - '00 Si valve is incompatible with your chassis) and use a '90 - '91 Civic EX sedan master cylinder.
Old Jan 31, 2009 | 07:00 PM
xXViperXx's Avatar
i'm hearing i need a NON abs PP valve, as you mentioned. I have a EK non abs valve, i'll compare soon to see if it looks about the same.
The brake booster, i have the booster and master cylinder from the SI. some say i need it, some say i don't. I know its bigger but would it be possible to use?
speed_demon018
Dec 15, 2012 07:11 AM
socialistic
Aug 4, 2010 11:38 PM
xXViperXx
Suspension & Brakes
Feb 1, 2009 08:31 AM
project93cpe
10
Nov 15, 2007 12:14 PM
Jonathan_ED3
Mar 24, 2004 04:51 AM
