Oil Leak around Vtec Solenoid
Old Jan 31, 2009 | 09:52 AM
taterbug's Avatar
Default Oil Leak around Vtec Solenoid
Question, Some oil leakage around the Vtec Solenoid (D16Z6). Looks like it's 3 bolts holding it to the SIDE of the head (not the 3 bolts on top). Must need the gasket replaced? If I take the 3 bolts out to replace it, is there anything that I need to know about? Anything gonna pop out?
Old Jan 31, 2009 | 10:00 AM
z6hatchboy's Avatar
Default Re: Oil Leak around Vtec Solenoid
i had the same problem once, its a $16 gasket that has to be replaced. Just take the bolts out and thats it, nothing but a little oil may come out
Old Jan 31, 2009 | 10:02 AM
batallic's Avatar
oil will come out not alot though
Old Jan 31, 2009 | 10:04 AM
kevinoneill's Avatar
no nothing will fall out, use some rtv sealant, i just replaced mine with the same problem, so far so good.
just make sure no oil is dripping out the side of the block that would reduce the sealing
Old Jan 31, 2009 | 10:05 AM
taterbug's Avatar
Kewl, Thanx. $16 bux, Wow!
ceyazzie
Aug 4, 2008 01:54 PM
fackyou
Sep 8, 2006 02:29 PM
b18c inside
Jan 16, 2006 12:05 PM
hybrid1990crx
Aug 12, 2005 10:41 AM
AdamQ3B85
Nov 1, 2003 02:45 PM
