chopping suspension help
Old Jan 30, 2009 | 05:39 PM
boostedefhatch's Avatar
Default chopping suspension help
how do i remove my suspension from my ef hatch 1991 i cut the springs i just need to take my suspension off to finish please help thanks
Old Jan 30, 2009 | 05:58 PM
ef9er0's Avatar
Default Re: chopping suspension help
What????
Old Jan 30, 2009 | 06:02 PM
garageEF's Avatar
say what?!
Old Jan 30, 2009 | 06:22 PM
ef_junky's Avatar
um why would you cut them? what are you doing?
Old Jan 30, 2009 | 06:26 PM
Italix's Avatar
This can't be good
Old Jan 30, 2009 | 06:54 PM
Originally Posted by ef9er0
What????
Originally Posted by garageEF
say what?!
Originally Posted by Italix
This can't be good
because i did and i cant go back now, i want to lower my car i already know about the risks of ruining my existing suspension so save it, i am just asking for help how to take my shocks/suspension off to remove the spring i cut the spring with them on now need to remove it any help appreciated, dont tell me no i already did it
Old Jan 30, 2009 | 07:13 PM
Twisted Image's Avatar
If you have even considered that cutting springs while loaded was a good idea, I dont thin anyone wants to help you go any further.
But basically. 2 bolts on top of strut, 1 bolt at bottom. Im not going to suggest seperating ball joints as that would more then liely be to complicated for you.
1 bolt below bottom strut bolt A shaped arm on front strut. inside of the lower control arm on front 1 bolt . should be able to swing the suspension ont he front far enough to get i out then.
Rear just drop the lower control arm out. 1 bolt on the inside under the gas tank the other on the spindle/trailing arm.
I would sugget an alignment after messing with all the suspension, but you have already chopped the springs....so I would throw you off my alingment rack, and tell you to go buy suspension not just rig your ****.
have fun eating tires up, putting stress and strain on your balljoints, cv shafts, and the rest of your suspension. When your struts start leaking...dont worry bout that, you will just get that awsome ricer bounce when going down the road
Old Jan 30, 2009 | 07:51 PM
wow thanks?
Old Jan 30, 2009 | 07:53 PM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
You do not have to drop ball joints or the rear control arm at all. Just separate the front strut from the fork and remove both of them and as far as the rear just take the strut out. Doing all that extra work might be needed if you are not strong enough with the stock spring in but since you cut them you will not have to fight the pressure of the stock spring. Really instead of cutting them you should have heated them with a load on the suspension to retain some kind of tolerable spring rate to support the car half-assed.
Old Jan 30, 2009 | 08:06 PM
jhammond_82's Avatar
Reject Papi
wow...just...wow. i mean...wow. why would you cut your springs? at least get ebay coil overs. just as low, but safer for daily driving.
Old Jan 30, 2009 | 08:14 PM
i already explained why i cut them
Old Jan 30, 2009 | 08:31 PM
traxxasx's Avatar
Take 2 14mm bolts on top in engine bay.
Take off fork on bottom of shock, by remove 17mm bolts, and 12mm bolt.
Old Jan 30, 2009 | 08:43 PM
now when i did that i was confused, i dont unbolt the bolt on that airbag looking thing correct i didnt, well thanks for your help
Old Jan 30, 2009 | 09:26 PM
ef yu's Avatar
this will not end well,
you cut your springs yet you don't know how to remove them.
next time, i hope you inspect things before hand otherwise your gonna end up ruining the car...er, uhh nvm. goodluck
Old Jan 30, 2009 | 10:47 PM
actually i did not just wake up and say hmm ima cut my springs bro, i have never actually removed it but have a pretty good idea, just trying to get as much usefull info as i can to get it done faster, thanks for your input
Old Jan 30, 2009 | 11:07 PM
My_EFsedan's Avatar
nothing is wrong with cutting springs. ive personally drove cars with cut springs for 6 years with my brother. feels just like it was never lowered. our shocks are not blown and does not bounce out of control. my instructor from school also said it was ok. my sisters car right now is on stock struts and cut springs riding like that for a year +. nothing's wrong with it up to date. for those who think its "bad" you either cut too much or did something wrong.
remove struts: 2 14mm on top under in engine bay for the top hats. 1 14mm between the strut and fork. 2 12mm for the brake lines. 1 17mm at the bottom where fork meets LCA.
Old Jan 30, 2009 | 11:21 PM
NlCK B's Avatar
welcome to hondatech where you get help with a steaming load of criticism lol
but yeah in refrence to the problem here i would unbolt the arm from the chassis instead of the ball joint that way you don't damage the ball joint
unfortunately i have to say it too cuting the springs is going to do more damage than anything this is obviously something you know by now but it's something to consider now if you just really dont give a flying **** and want the car low without spending money then go ahead and cut the springs or you can spend a little bit of money and buy these
http://cgi.ebay.com/ebaymotors/88-91...spagenameZWDVW
or these
http://cgi.ebay.com/ebaymotors/Honda...spagenameZWDVW
they are cheap and a little safer than cutting good luck with what ever direction you choose
yay it's my 200th post
Old Feb 1, 2009 | 07:04 PM
http://cgi.ebay.com/ebaymotors/88-91-HONDA-CIVIC-CRX-JDM-SPRINGS-COILOVER-COIL-OVERS_W0QQcmdZViewItemQQcategoryZ33582QQihZ001QQit emZ110344626170QQrdZ1QQsspagenameZWDVW
or these
http://cgi.ebay.com/ebaymotors/Honda-Civic-88-91-92-00-Coilover-Lowering-Spring-Blue_W0QQcmdZViewItemQQcategoryZ33582QQihZ026QQite mZ390027266544QQrdZ1QQsspagenameZWDVW
got all 4 cut today no problems, a little bouncy not to bad but it scrapes and its low i mean low looks really clean have pics tomorrow thanks for the help guys
JDM3STAGEVTEC
Honda Civic (2006 - 2015)
Apr 26, 2009 08:16 PM
GumballNA
Oct 16, 2002 05:00 PM
TypeR 508
May 21, 2002 09:12 PM
