Hey Gas pump problems please help_HONDA_
Old Jan 30, 2009 | 04:49 PM
LSXFEIND's Avatar
Default Hey Gas pump problems please help_HONDA_
hey guys my gas pump doesnt want to turn on would anybody know why???? i checked all fuses and the main relay everything is ligit!? any guesses Hoping its not dead? it was working before?? one thing is that i accedintly made bad contact and fried the 80 AMP i replaced it and everything works but no pump!
Old Jan 30, 2009 | 05:31 PM
h_s's Avatar
h_s
Default Re: Hey Gas pump problems please help_HONDA_
sounds like your pump is fried, to make sure, take a test light and hook it to the + wire going to your pump, if it lights, your pump is messed
Old Jan 30, 2009 | 05:37 PM
LSXFEIND's Avatar
ok man thanks ima try that
Old Jan 30, 2009 | 08:44 PM
Juan_Mitosis's Avatar
Yup. Pretty simple diagnose. If your fuel pump is receiving power and its still not working, might as well do 2 things.
1. Fuel pump kill switch with OEM looking wires
2. REPLACE the fuel pump
Good luck!!! (b)
Old Jan 31, 2009 | 05:27 PM
LSXFEIND's Avatar
hey well it has a kill switch but i switch it and nothing happens maybe i burnt it out?
Old Feb 6, 2009 | 09:34 AM
Remove the switch and wire it straight through.
Switch could be bad.
Maybe some bad wiring caused a short
Recheck your fuses.
Check for power going into your pump. Should read 12V I believe. ( At the moment of actually turning your key to the ON position)
Old Feb 7, 2009 | 04:51 PM
LSXFEIND's Avatar
Still nothing
Originally Posted by juan_mitosis
remove the switch and wire it straight through.
recheck your fuses.
Check for power going into your pump. Should read 12v i believe. ( at the moment of actually turning your key to the on position)
civic_pteg
Audio / Security / Video
Jan 24, 2016 06:23 PM
bads2k
Jun 7, 2010 06:31 PM
00trdtaco
Aug 20, 2009 09:42 AM
00trdtaco
Aug 20, 2009 06:42 AM
dustin
Mar 1, 2002 07:33 PM
