FS part out type r itr parts whatever is left out of my wrecked itr
PHOTOBUCKET LINK TO ALBUM http://s239.photobucket.com/albums/ff287/beasty18c5/
Type r itr tranny needs synchros on 2nd gear $600
Red front seats from 2001 $700 missing original headrests
cw 1997 Rear bumper small hole from exhaust tip $100
Front calipers new rubber seals $150
5 lug bolt hub left side knucle $100
5 bolt lug rear trailing arms $250 left side
brake lines all 4 $50
right side pasenger window $40
right side pasenger power door lock actuator $50
door panels $200
random small plastic pieces like caps and other small items $10
interior dome map light $20
miscellaneous parts...$10
only 2 type r itr rims wheels $100 a rim
4 cw championship white center centre caps $80
ABS modulator $150
abs rear sensor wires left and right $40
front sway bar $100 rear is sold
complete left front shock absorber with fork $50
AC condensor $100
AC compressor $100
AC lines $100
steering column $200
door handles with locks and trunk lock plus ignition with matching original keys + spare + valet keys $300
3rd brake light $20
pedal assembly clutch brake gas foot rest $60
wiper motor assembly $60
rear speaker covers $20 pair
holly **** handle $10
fuse box under dash $60
fuse box engine bay $60
cabin wire harness hooks up the ecu ecm goes to the fuse box $250 obd2a
other wiring harness i may have ask dash door ...
steering column plastic cap cover $20
trunk release and fuel release plastic piece $10
hood hinges $10
cigarette lighter asembly centre center console with the shift boot and cup holders $80
light dim dimmer switch plastic piece $10
SRS pasenger airbag $100
SRS air bag module $100
SRS unit plastic cover the one by the fire wall behind the radio $10
battery mount $10
left and right pillar covers $30 pair
various engine mounts tranny transmission mounts $50 each obo
AEM big brake kit $300
Racing Hart RacingHart cp 035 cp035 18" only 2 may have a 3rd one wheels $200 each
5 zigen wheel 18" $100
right side door power window actuator regulator assembly $50
will be parting out my dash air vents $20 each
center air vent heater control assembly lights up amber $100
Amber radio with code $100
door panels $200
ABS modulator $150
AC condensor $100
AC compressor $100
AC lines $100
3rd brake light $20
hood hinges $10
battery mount $10
You have the 3rd brake light? Is the one that goes in the hatch window? If so please pm me bc I have been searching all over for one.
Beasty18C5
Jan 29, 2009 06:51 AM
