s2000 Oil pump. Upgrade your weak K series pump!
This can be a potential upgrade for the K series oil pumps, which spin about 1.6 times faster than the crank does. So at 8000 rpm your pump is spinning at around 13k. Don't let your stock K pump be the limiting factor in your build. Rev to the moon with this perfect condition OEM s2000 pump, only a few mods are needed to fit this and make it work.
This pump is unmodded.
Pick it up for 150! It's about 350 at the dealer.
call me if you are serious. SERIOUS buyers only. I'm in westchester, ny.
914 497 7496
914 497 7496
s4play
Dec 5, 2011 05:41 PM
