B18c5 wiring
Old Aug 7, 2002 | 07:58 PM
88 rex's Avatar
Default B18c5 wiring
I plan on swapping a c5 in with in the next year or so, so basically I need to know what kind of stuff i need to be looking for. I would like to go OBDII, but if I do that I am assuming I will need all the wires to go along with it. Will I also need a new gauge cluster and other electrical components?? If so what gauge cluster should I get and how much should i spend??
Also, how much $$$ would it take to get it in including cost of installation and ALL equipment????
Thanks in advance
Old Aug 7, 2002 | 08:19 PM
HybridFiend's Avatar
Default Re: B18c5 wiring (88 rex)
If you want to make it easy, you get all the electrical components from a B16A swap and use them on the ITR engine. Yeah you could go all out OBDII, but then you will be spending a lot more money on converting. You could also try OBDI with a pigtail harness, but why not do it the easy way?
Old Aug 7, 2002 | 08:48 PM
bryant's Avatar
Default Re: B18c5 wiring (HybridFiend)
OBDII sucks. just do OBDI. You will be much better off. Wiring will not be to tough if you get an Si or HF, with a DX there will be some more work involved
Old Aug 7, 2002 | 09:46 PM
Mugen Dom's Avatar
Thanks in advance
followed me here to ****....odb2 will make teh car run up to teh standards of our shitty state and will let teh car run right ill let u talk to macky hes doen it and has obd2 in his std there is a lil bit of wiring involved but who cares we can do it in a day i mean uhh a few days
Old Aug 7, 2002 | 10:03 PM
E-lude78's Avatar
Default Re: B18c5 wiring (jdmb18hatch)
since I'm runnin OBD1 with B17a, I can just swap longblocks, right?
Old Aug 7, 2002 | 10:07 PM
Mugen Dom's Avatar
Default Re: B18c5 wiring (Mista B-one-seven)
technically sorta teh obd2 plugs are diff i dunno if ur distribuiter will mount up or not and teh fuel maps i imagine are quite different between the gsr and the c5....u could run an obd1 setup easily and run a zydne ecu or something along those lines
Old Aug 8, 2002 | 03:38 AM
88 rex's Avatar
Haha.....Nah, i've been here, I just never posted anything. I thought I would take my search to another forum to see if I could get some other answers.
If I were to go OBD I then i can't use the ITR ECU, which to me kinda sux. I want to use the ECU that was designed for the engine because to me I would think it would run optimally with its factory ECU.
OR, will it run equally the same or better by switching to OBD I or non-OBD?
spyderdrifter
Aug 22, 2016 05:52 AM
xXDeathMaliCeXx
Feb 8, 2012 09:51 AM
JDpower
Oct 1, 2011 03:07 PM
mtflyboy25
Aug 24, 2011 06:00 AM
crxjake
Dec 9, 2003 09:57 PM
