91 LX Sedan Rear Disc?
Old Jan 30, 2009 | 11:01 AM
91civiclx's Avatar
Post 91 LX Sedan Rear Disc?
i recently did a rear disc conversion on my 91 LX off a 90 DA and i've read a lot about the whole e brake cable situation. some say 91 CRX Si some say the DA's will work if rerouted. I'm thinking about going with the 91 CRX Si is i get a confirmation that it fits on my car? Just wondering what you guys can confirm for me...
Old Jan 30, 2009 | 01:27 PM
4drEF's Avatar
Keyboard Humorist
Default Re: 91 LX Sedan Rear Disc?
I haven't done the swap, but I think it's the DA cables.
I have no idea if you are supposed to use 4dr or 2dr teg cables though.
I tried starting a thread to gather specifc brake info for EF/ED only, but it got locked... inso is supposedly lurking the FAQ.
This is all I found in the FAQ
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/how-put-x-brakes-your-96-00-ek-civic-revised-upgrade-chart-1513752/
(I skimmed though it... found nothing for our sedans)
Good luck!
Please PM me if you figure it out and get it working!
Old Jan 30, 2009 | 02:25 PM
iheartteal's Avatar
not sure about the 4 doors, but u gotta use the da cables on the hatchbacks, also be sure you use the toe arm from the ef not the da, the da arm is shorter
Old Jan 30, 2009 | 03:32 PM
91civiclx's Avatar
https://honda-tech.com/forums/showthread.php?t=1513752
Good luck!
yeah i read somewhere but can't remember if it said the 2 or 4 door
Old Jan 30, 2009 | 03:34 PM
91civiclx's Avatar
yeah i kept the ef toe arm on there and i used the ef LCA also but i wasn't all that sure about the UCA they may be the same size... as far as the cables go imma keep looking around while somebody else gives there input just to be certain, thanks man
rexracer626
Jun 15, 2010 09:49 PM
jb0705
May 11, 2009 05:31 PM
Vtak DOHCTA
11
Jan 9, 2006 07:55 PM
quintanaporvida
Aug 13, 2005 05:06 PM
Sleeper Sii
Sep 15, 2002 03:44 PM
