# 1 number one fuse blowing popping ???
My number one fuse keeps popping. So i am assuming i have a short somewhere. Any ones thoughts on where i might start checking. Possible problems people have had in the past.
Thanks.
Thanks.
Thanks thats alot more then what it says on the the little fuse thing lol.
I will source out those several things and see if i am having a possible grounding issue.
I noticed. Not completely a noob. Just havent really mess around with my Crx to much. Also wasnt sure if there was maybe a little know secret to certian fuses popping. Always worth a shot. I would have search probably but i hate the new search. Not nearly as easy for me as the old system.
If it pops every time you put it in, disconnect everything on that circuit, put in a new fuse, and start plugging stuff in. Most likely, when the fuse blows, you have found your problem.
Na, it doesnt pop everytime i put one in. It just decides to pop when it wants to. I could go days/weeks or i could only go 2 feet. Its an awesome electrical issue probably haha
do you have an aftermarket radio? I have seen them wired right to the fuse box with no fuse. check the wires its a intermittent short somewhere
I'm going to put a bet on te reverse light circuit. It runs to the trans and to the back of the car, everything else sticks to the strut towers and dash area.
