measuring compressor inducer wheel?
Old Jan 30, 2009 | 08:49 AM
turbo-crx's Avatar
Default measuring compressor inducer wheel?
how do i do this exactly? Do i just unbolt the compressor cover bolts and the housing slides off?
Old Jan 30, 2009 | 08:57 AM
Schister66's Avatar
Man U FTW
Default Re: measuring compressor inducer wheel?
Yessir...Make sure to take accurate measurements of the top and bottom of the compressor wheel. There is a formula floating around HT somewhere that tells you how to calculate the exact AR from those 2 measurements
Old Jan 30, 2009 | 09:03 AM
turbo-crx's Avatar
thanks man for the info.
Old Jan 30, 2009 | 09:09 AM
twkdCD595's Avatar
You can find alot of good information also on the following link.
http://www.turbobygarrett.com/turbob...o_tech102.html
Old Jan 30, 2009 | 09:22 AM
Bseriescivic5's Avatar
If the housing is a PITA coming off, what is the best way to persuade it to come off? Rubber mallett?
Old Jan 30, 2009 | 10:14 AM
twkdCD595's Avatar
yea carefully tapping around the perimeter on the housing where it seals to the chra till it comes loose with a rubber mallet is probably your best bet if its not coming off by hand.
Old Jan 30, 2009 | 10:38 AM
BlakeJ53's Avatar
good info
Schister66's Avatar
Man U FTW
One thing to be careful of, is that some turbos have a little rubber O-ring around the perimeter of the backplate. What this basically means is when you take the housing off, be careful not to twist it back and forth a lot or you risk tearing that O-ring
Old Feb 2, 2009 | 05:03 AM
Good info, thanks
Old Feb 2, 2009 | 06:03 AM
SPOOLINmatt's Avatar
Don't you mean Calculate the TRIM of the wheel?
Old Feb 2, 2009 | 06:32 AM
TheShodan's Avatar
Moderator
Measuring the wheels of a turbocharger
Measuring trim. I've this all over H-T. Needs to be a sticky now.
Old Feb 2, 2009 | 06:44 AM
dpetro1's Avatar
very true. and any new topic with the words trim or a/r should be banned
VTECth1s
Sep 9, 2011 01:19 PM
TegR
Feb 26, 2007 01:51 PM
Corporation
Sep 25, 2004 03:00 PM
Wideopentuning
Jul 15, 2004 07:44 PM
Stock@$$GSR
Apr 18, 2002 06:22 AM
