NeedA quick answer please. what mirrors fit?
you might want to look deeper into this cause i installed crx spoon mirrors on my hatch and had to modify the bottom because it hit the trim........
yeah once again i'm NOT 100% sure thought but i'm pretty sure i got my passenger mirror of of a sedan or crx i'll check and see if they have the same part numbers
i'm really confused on this now there are mixed answers on this subject and i cant find part numbers
here is what i found
https://honda-tech.com/forums/showth...hlight=mirrors
that's what i found and it just confused the hell out of me
I swapped civic and crx mirrors before. They are slightly different, and usually only 2 of the three mounting bolts will work, but it can be done
spend 40 bucks on ebay and just get "spoon" mirrors made for YOUR car. they look nicer than the big ugly's on there now.
they will work, if you spend 5 minutes with a file or like 10 seconds with a dremel you can enlarge the hole behind the mirror( only like 1/16- 1/8") and the mirror will bolt on fine with all three bolts. 90-93 integra ones will also work as well, same thing the hole must be slotted and the mirror will bolt right on. they might be easier to find in power versions
i put power da mirrors on mine and it changed the whole front view of the car and i wired them up with the factory da switch everything fit perfect.
spoon knock off mirrors dont fit on 88-91 civics, they only fit crx. i bought a set and sold them because it woulve been a hell of alot of hassle to get them to fit.
http://cgi.ebay.com/ebaymotors/JDM-S...Q5fAccessories i'm pretty sure they would fit.
does it matter if the da is coupe or sedan? and also will the mirror from an acura legend fit the crx? ( those mirrors can be folded)
JUN.
12
Nov 14, 2010 11:41 PM
2nxcrx
Mar 25, 2005 12:10 AM
Yellow Dragon
12
Sep 1, 2002 04:47 PM
