Lighting HID/Xenon kits, Retrofits and Associated Topics
park, tail, and dash lights are not working on Fifth gen prelude
Old Jan 30, 2009 | 06:37 AM
Luder88's Avatar
Default park, tail, and dash lights are not working on Fifth gen prelude
hey,
ok heres the thing, i was driving home from work and all of a sudden my dash lights, parking light, and tail lights jus went out. and above that it doesnt even ding when the car is off and the switch is on the parking lights. i checked all the fuses the next morning and they all seemed fine. i have no idea what the probable cuase could be. does anyone know what could have happened and how to fix it. thnx
luder88
Old Jan 30, 2009 | 05:58 PM
prelude1897's Avatar
Default Re: park, tail, and dash lights are not working on Fifth gen prelude
check your taillight fuse inside the car to see if it's any good. Also check under the hood. If both fuses are good, then there's a red/black wire under the dash going to the fuse panel. I believe it's in a white plug. That wire might be loose
Old Jan 31, 2009 | 01:29 PM
Luder88's Avatar
thnks man. but i got the thing fixed. I had a mechanic look at it and everything, he said that the problem was that the fuse box it self was bad. so i jus had him rig the the thing and got everything up and running
Old Feb 2, 2009 | 06:51 AM
I'm pretty sure he just told you a bunch of BS, cause I've never heard of a whole fuse box going bad. I'd double check those fuses, cause if you're running the dash lights off another fuse, you risk messing up more stuff
PsXtreme
Aug 24, 2015 05:52 PM
ltec
Feb 13, 2013 05:17 PM
Toanz
Sep 26, 2008 08:22 PM
jdmdc22
Jun 13, 2008 11:01 AM
KaoticSnow
Jan 25, 2007 09:52 AM
