Newbiee It want start
I've been reading on here that i don't need the CKF i can bypass it. If thats the case why want my car start. It was been sitting since March 07 nothing wrong just stop driving. I changed sparks plugs (nkg) today. I'm not getting spark. Using a multimeter how do i check the ignition coil for voltage? Or what should i be checking? Again pictures are a plus for me. the car is a 96 civic lx 4 door. automatic tranny
learn proper English Jethro i can barely understand it.
if your not getting a spark your coil has most likely gone bad and they cost about 70-85$
as zak said, please write in english so we can all understand you.
and as 00 JDM said, check you distributor for any corroded points. also check the voltage coming from the ignition coil by using the connection points on it
hurleyboarder21
Apr 12, 2004 07:22 PM
kieron
12
Feb 4, 2004 06:40 PM
