Valve Cover Question
Old Jan 29, 2009 | 03:44 PM
Inaccurate's Avatar
Default Valve Cover Question
Im gonna paint my valve color soon, but idk what paint or whatever to use,
can someone helo me out?
Old Jan 29, 2009 | 04:54 PM
edtek's Avatar
Default Re: Valve Cover Question
regular automotive paint,1200,1500,2000grit sandpaper(wet sanding) sandblaster or aircraft stripper,primer, beer and patience! its not hard at all!
make sure you clean it with soap and water(before you strip the paint and after you strip the paint)
then primer (let it dry for 10 mins at least)
paint 2-3coats (spray at least 1 1/2ft away) let it dry for 24hrs
wet sand 2000grit
clear coat and re sand
take a break,step back and appreciate!
Old Jan 29, 2009 | 08:23 PM
EKFerioHawaii's Avatar
Lets see if i can add my .02 cents.
Exactly what he said^
I tend to add these steps in between. I clean valve covers first with purple degreaser w/ wire brush. Then clean again with tide w/bleach. Then clean with an automotive silicone remover.
Automotive painting = 90% prep + 10% application
C-187
Paint and Body
Apr 7, 2009 03:02 PM
mannydhanju
Jan 22, 2009 08:36 AM
methos713
Paint and Body
Sep 21, 2007 05:27 AM
mountaindewguy
Mar 9, 2005 06:37 PM
Jebus
Mar 29, 2003 11:06 AM
