want to make my crx obd1
Old Jan 29, 2009 | 02:28 PM
TURBO+GSR+CRX=?'s Avatar
Default want to make my crx obd1
i want to take out the whole harness and put an obd1n harness in anyone no whats the easiest way i mean i have it wired obd1 but i want to make it all obd1...right now i only have the injectors and dizzy with the clipover to a p28 on my gsr crx
Old Jan 29, 2009 | 02:39 PM
D16SiHatch's Avatar
Default Re: want to make my crx obd1
why would you want to do that. if you have an engine harness thats obd1 you would have to have a cabin harness that is obd1. so basically you'd be swapping the entire dash from the obd1 vehicle that your getting the engine harness from in order for that to work.
Old Jan 29, 2009 | 02:42 PM
93formula's Avatar
you dont switch harnesses you convert your existing one.
you dont really need the obd1 injectors for the conversion either. what you do need is the ecu, the jumper harness, 4 wire o2 sensor, and dist.
Old Jan 29, 2009 | 02:45 PM
see i no that i have that but what i want to do is swap it all out i want it to be complete obd1 that way i dont convert nothing or mess with wiring
Old Jan 29, 2009 | 02:50 PM
4drEF's Avatar
Keyboard Humorist
You are complete OBD1 right now.
What you want is complete OEM and it's not worth it to most people.
You need to pull your entire interior harness and put in the OBD1 one.
Now, if you are still interested in staying 100% OEM then you will have to swap out everything in your stock dash to the OBD1 harness donor dash. Either mod every component the harness plugs into your dash or mod the dash to fit your car (ugly).
Theeeennn... you might have to cut into the harness anyway to get it to fit your tail lights and dome light and whatever else.
There is no staying OEM through any of this - something gets modded to fit your chassis.
D16SiHatch's Avatar
but see the thing is you are asking for a hell of a lot of trouble by trying to do that. as i said you would have to have an obd1 cabin harness if you intended on using an obd1 engine harness. which means you would have to take out your crx dash and install an obd1 dash, because an obd1 dash harness will not connect up to your crx dash. so if you want to try swapping an 92-95 civic or integra complete dash in your car then have at it. otherwise this isn't going to work.
ninja edit: or do what 4drEf said, which means tons of cutting and splicing. good luck ever getting that working 100% correctly. and it wouldn't be oem at all like he said.
Old Jan 29, 2009 | 02:51 PM
Deetz's Avatar
Crazy Honda Guy
lets keep it simple.....
obd0-I harness
obdI ecu
4 wire heated o2 sensor
(may need newer style downpipe for single O2 sonsor)
obdI dizzy
Thats it!!
efrunner09
10
Sep 21, 2009 02:57 PM
H9Omega
Dec 1, 2006 11:00 AM
myEK=slow
11
Aug 21, 2006 08:20 PM
E_F_9
Dec 22, 2005 02:26 PM
