JDM 4-1 arrived.... Question??
I did a search but found no content really. Any of you guys with the JDM 4-1 clean up the weld on the inside of the primaries? I dont want to Port it to much right near the welds. Just wondering what u guys have done or just leave it alone? JDM 4-1 and SMSP modded Cat go on this weekend. Cant wait!
From: If ignorance is bliss... I am in the happiest, place on earth.
I did- what I had done was I took the header to my local welder; had him reweld around the outside of the flange- then took a nice carbide bit and an angle grinder and went to town the on the inside. The good bit made short work of it so I highly suggest getting quailty here.
Also; checkout Fastline Performance (see sig for linky
)- they have a niiice skidplate for the header that works great!!!
good luck with it!
later
matt
)- they have a niiice skidplate for the header that works great!!!good luck with it!
later
matt
http://www.sandmracing.com >> mods and upgrades section.
(this was covered last week, and the week before, and the week before that...)
I have a diesal iron skidplate, Its efficently taken out 2 possums dead on impact. They were unavoidable or else I would have tried to move out the way. Also its been thru VAs most treacherous rds and highways with minimal surface skruffs.
BTW, Champ nice avatar
for the DIY!! it ain't pretty, but from what you said, it gets the job done!!gald you like the avatar!! although someone else on this board has the exact same one!!
later
matt
good luck with it!
later
matt
later
matt
hahah I'm not sure what's worse....Va roads or possums
http://www.fastlineperformance.com/skidplate.htm
