Linkage problem and lil sputtering
Sup ppl. I have 2 little problems on my hand. I have a 94 civic with a Gsr. 1st question. The piece between the bar linkage and the tranny disconnected when I was driving, i belive the pin popped out, i was wonderin where i can get that pin and clip at, or if i can just put a little bolt that fits. 2nd I just had my timing and valve lash adjusted. few weeks before the sputter, (it seems like when the car is warmed up its sputters.) ignition, fuel? Any help would be appreciated.
Thanks.
Thanks.
you need to replace that linkage pin with the roll pin and clip more then likely the reason it is missing now is somone replaced it with a bolt and things came apart
ramz7887
May 4, 2009 03:24 PM
eghatchproject
12
Nov 22, 2003 08:28 AM
JohnnyEF
May 1, 2002 05:45 PM
