act clutch kit vs f1 racing clutch kit
how is the f1 stage 2 with flywheel compared if I want to buy the HDSS from act???
cuz there's alot of people saying that the f1 stage 2 with flywheel is a good combination, but those are ebay clutches, so I am afraid they are garbage (like 75% of ebay stuff)
I mean both of them will run me 500 dollars, but one includes the pilot/throwout bearing and a flywheel
vs the act in which is only the disk and pressure plate....
my s2k is not a daily drive.....just a weekend car
I want something that will be better than oem clutch, and it has to be in the 600 dollar range including release/pilot bearing....
thx in advance
thx in advance
Cool Cool Island Breezes. BOY-EE
They're both garbage. I've always really hated ACT's stuff. The F1 just seems like ebay trash.
What's wrong with an Exedy replacement? How much power are you making to need a more agressive clutch?
Check Ebay listings or contact an exedy dealer. There are a couple of exedy dealers around here. One is www.thmotorsports.com.
They are more expensive. But....why cheap out on a clutch of all things?
Munkyw3rkz.webs.com
never liked exedy personally, always had slipping issues with it... kuz of power of course, im sure if i was underpowered it would have been fine.i used a set of that F1 clutches once on a SOHC D series turbo i was making 250ish whp and 230+Ft lbs... held up fine on the street and track...
pretty sure f1 clutches are made by SECO. I bought a "SPEC" stage 3 clutch from someone for my turbo D build, but it turned out not to be a spec clutch. It had no marking on it except a Pressure Plate that was stamped SECO. looks identical to ones found on ebay.
SECO is an OEM clutch manufacturer for many companies.
redlinexd
Transmission & Drivetrain
Apr 8, 2012 10:31 AM
