Which headlight bulbs should I get?
Old Aug 7, 2002 | 05:33 PM
Double 0 Seven's Avatar
Default Which headlight bulbs should I get?
What are some good ones that are close to HID but don't burn out the friggin connector?
Old Aug 7, 2002 | 05:40 PM
champITR's Avatar
From: If ignorance is bliss... I am in the happiest, place on earth.
Default Re: Which headlight bulbs should I get? (Double 0 Seven)
CATZ zeta system- looks very close to HID
later
matt
Old Aug 7, 2002 | 08:11 PM
Default Re: Which headlight bulbs should I get? (champITR)
The zeta system is too expensive, I just need some semi cheap bulbs that won't fry the headlight conntector. Thanks
Old Aug 7, 2002 | 08:13 PM
Rguy's Avatar
Voted Best Looking GDD Poster
25 Year Member
Community Builder
Community Influencer
Active Streak: 60 Days
Just use regular bulbs, you dont need that fake *** look of HID's.
Old Aug 7, 2002 | 08:32 PM
STC's Avatar
STC
Default Re: Which headlight bulbs should I get? (Rguy)
PIAA Hyper White, I had those before I got HIDs. The PIAA's are a lot brighter than stock.
Old Aug 7, 2002 | 08:33 PM
tc's Avatar
tc
CATZ Galaxy white looks good. Or their new Aqua white is suppose to be even more of a pure white.
Old Aug 9, 2002 | 12:14 AM
Nvious R's Avatar
From: Bitch Slapping Your Ass Around The Twisties n Doin, it Doggy style At a theater near you
Default Re: Which headlight bulbs should I get? (tc)
you need some of these
Old Aug 9, 2002 | 02:27 AM
GapxGuy's Avatar
Sushi Buffet Champion
Default Re: Which headlight bulbs should I get? (Nvious R)
Good lord that's nice. What are they? Real HIDs?
Old Aug 9, 2002 | 07:54 AM
disordeR's Avatar
Default Re: Which headlight bulbs should I get? (GapxGuy)
yeaup
Old Aug 9, 2002 | 07:59 AM
azn98R's Avatar
Default Re: Which headlight bulbs should I get? (disordeR)
Funny that this subject came up.... one of my PIAA's just went out after 2 -3 yrs of usage... too poe to get HID's. Was thinking of the catz aswell, but don't know if I wan to spend the money again. The PIAA's are really nice though...
Old Aug 9, 2002 | 08:43 AM
Larkin W.'s Avatar
Use OEM unless you can afford real ones. I have gone through 2 sets of PIAA super plasmas. Luckily 2nd one was free. 1st set went out in under 3 months. Then I realized that fake bulbs are a waste of money because they don't last long enough. So until I have $$ to buy the real deal, I'm stayin' OEM.
Peace,
Larkin
Old Aug 9, 2002 | 08:47 AM
PM-Performance's Avatar
Default Re: Which headlight bulbs should I get? (EbboyPSi)
ive had the same piaas for 4yers now , never blew out and took em from car to car. to car to car to car to car to car. just to give you an idea.
Old Aug 9, 2002 | 03:08 PM
Nvious R's Avatar
Yup, OEM Acura HID's made by stanley. Those were off a CL Type S. You like?
Old Aug 9, 2002 | 05:26 PM
uNF$@#!'s Avatar
actually, what your asking for is something like the best of two worlds..well, not really.
the deal is that normal bulbs use a filament wire going accross. this heats up, and cools down when the bulb is on/off. this causes a problem since theres a connection that keeps heating up cooling down, it will, eventually, break.
now the more wattage you throw thru the filament, the more prone it is to break. heat = causes items, including filaments to break/warp.
so for like the cheap 15 dollar HID look bulb or the expensive piaa super ultra neon plasma bulb running at 100watts, or 120watts, the life span is short.
the reason HID's are so bright and use 35 watts (less than the standard 55 w bulb) is because its a entirely different way of creating light. using a huge capacitor (the ballasts) it literally throws sparks of electriciy accross the arcs of the bulbs. notice that the hid bulbs do not have a filament, instead 2 points where the light travels accross. this is why hid bulbs can produce the amount of light they do and still outlast normal halogen bulbs.
and for 300 dollars for the cheapest of the cheap hid kits, i think it would be a worthwhile investment, even if money is a huge issue. the $100+ for the piaa bulbs that look like HID but are much duller than HID is just not worth it.
Old Aug 9, 2002 | 06:41 PM
uNF$@#!'s Avatar
did you tint the picture blue?
Old Aug 9, 2002 | 06:52 PM
Bud's Avatar
Bud
New User
Default Re: Which headlight bulbs should I get? (Soup ****)
I think the blue is from the glare on the camera lens.
Looks nice.
Old Aug 9, 2002 | 06:57 PM
uNF$@#!'s Avatar
Default Re: Which headlight bulbs should I get? (Bud)
its very odd though, as the 4300k are not blue at all. they are on the yellow/white spectrum of color output...
Old Aug 9, 2002 | 07:03 PM
Mai_CL-S's Avatar
New User
Default Re: Which headlight bulbs should I get? (STC)
Piaa's
Old Aug 9, 2002 | 07:07 PM
csufweed's Avatar
Default Re: Which headlight bulbs should I get? (Typ3 R Us)
9005 stock replacements!
Old Aug 10, 2002 | 09:24 AM
Jsracingintegra
Guest
Posts: n/a
Default Re: Which headlight bulbs should I get? (csufweed)
Isn't 9005 for the high beams?
Old Aug 10, 2002 | 09:28 AM
IGGY's Avatar
Default Re: Which headlight bulbs should I get? (Jsracingintegra)
"Hypa white lights, ultra violet lenz....sumakuma tires and dey gotta be run flat"
IGGY's Avatar
9006 are high beams
Old Aug 10, 2002 | 09:30 AM
NINJA's Avatar
Yup,
9005=low beam(Canadian), + High beam
9006=driving lights
Old Aug 10, 2002 | 09:34 AM
Jsracingintegra
Guest
Posts: n/a
Default Re: Which headlight bulbs should I get? (NINJA)
Thanks I just looked at a high beam bulb and it's 9005.
Old Aug 10, 2002 | 09:42 AM
IGGY's Avatar
really? I remember reading on vtec.net that a cheap mod for lights is to get the 9006 and remove one of the pins so it fits in the low beam spot, and you have highbeam bulbs in for low beam bulbs. I could have mixed the numbers around though.
Are you using those bulbs on your JDM front?
