When Removing Rear Wiper on 95 Integra, How do you remove the arm? It won't come off!
Old Aug 7, 2002 | 05:28 PM
MRDC2's Avatar
New User
Default When Removing Rear Wiper on 95 Integra, How do you remove the arm? It won't come off!
I am removing my rear wiper on my 95 Integra right now and have gotten to the point where the wiper arm bolt is off, but I can't seem to pull the arm off the assembly. I am pulling pretty hard too. What am I doing wrong?
TIA
REDTEG
Old Aug 7, 2002 | 05:42 PM
Chris's Avatar
Default Re: When Removing Rear Wiper on 95 Integra, How do you remove the arm? It won't come off! (RedTeg)
Here is the trick..
LIFT the wiper arm up (like you are washing the window)
Pull the base.. Straight UP, off the glass.. might have to wiggle it a little.
HTH.
Old Aug 7, 2002 | 05:43 PM
Chris's Avatar
Default Re: When Removing Rear Wiper on 95 Integra, How do you remove the arm? It won't come off! (Chris)
Oh.. make sure you unbolted it first..heh
Old Aug 7, 2002 | 05:54 PM
MRDC2's Avatar
New User
Thanks for the Quick Reply,
But....It still won't come off. It is unbolted, I am pulling straight up very very hard and still it does not even budge. Any one ever have this happen? What the H am I doing wrong?!?
Old Aug 7, 2002 | 06:21 PM
Sima's Avatar
Yea, I had the same problem when taking mine off. I had to work at it for about 5 mins. I guess b/c it had been on there for so long that it was kind-of stuck. Just keep working at it by wiggling it, but make sure you do not damage the glass.
Old Aug 7, 2002 | 06:39 PM
MRDC2's Avatar
New User
Default Re: When Removing Rear Wiper on 95 Integra, How do you remove the arm? It won't come off! (Sima)
WOOHOO!
I finally got it off. That was entirely way too difficult. I ended up using a fairly large flathead screwdriver and wedged it beneath the end opposite the arm where there is a little indent. I then placed my hand under the end of the screwdriver and pulled up really hard. Thanks for all the help.
RedTeg: Who deserves to be labeled a newbie again.
codenamezero
Apr 20, 2011 06:56 PM
9.3.S.I.L.U.D.E.
Apr 1, 2009 09:43 AM
MarkZeroNine
Sep 2, 2005 09:38 AM
FakeJDMEF8
Sep 26, 2004 07:39 PM
