fs type r itr parts whatever is left out of my wrecked itr
Old Jan 28, 2009 | 09:40 PM
Beasty18C5's Avatar
Default fs type r itr parts whatever is left out of my wrecked itr
PHOTOBUCKET LINK TO ALBUM http://s239.photobucket.com/albums/ff287/beasty18c5/
2.5" stainless steel exhaust with 2.5" Carsound cat $250 (the axel back section was replaced if you look closely)
Type r itr tranny needs synchros on 2nd gear $600
Red front seats from 2001 $700 missing original headrests
cw 1997 Rear bumper small hole from exhaust tip $100
calipers front and back I cleaned up the fronts need new rubber seals $200 for all 4
5 lug bolt hub left side knucle $100
5 bolt lug rear trailing arms right is bent $300 ($250 left side $50 for the right hub)
rear calipers $100
brake lines all 4 $50
right side pasenger window $40
right side pasenger power door lock actuator $50
door panels $200
e-brake handle $20
random plastic pieces around steering column and bottom other interrior bits $10 each ie interior light,trunk light all other small
miscellaneousparts...$10
only 2 type r rims wheels $100 a rim
ABS modulator $150
abs rear sensor wires left and right $40
front sway bar $100 rear is sold
complete left front shock absorber with fork $50 right side was damaged
complete stock air intake box and all the other plumbing $150
AC condensor $100
AC compressor $100
AC lines $100
steering column $200
p73 itr ecu $200
door handles with locks and trunk lock plus ignition with matching original keys + spare + valet keys $300
3rd brake light $20
pedal assembly clutch brake gas foot rest $60
interior carpet $100
trunk carpet $20
wiper motor assembly $60
rear speaker covers $20 pair
holly **** handle $10
fuse box under dash $60
fuse box engine bay $60
engine wiring harness $250
cabin wire harness hooks up the ecu ecm goes to the fuse box $250 obd2a
other wiring harness i may have ask dash door ...
dashboard with wiring harness for cluster , radio $150
steering column plastic cover $10
trunk release and fuel release plastic piece $10
hood hinges $10
cigarette lighter asembly centre center console with the shift boot and cup holders $80
light dim dimmer switch plastic piece $10
e-brake emergency brake handle $20
stock shifter $20
SRS pasenger airbag $100
SRS air bag module $100
SRS unit plastic cover the one by the fire wall behind the radio $10
battery mount $10
heater core assembly $150
left and right pillar covers $30 pair
various engine mounts tranny transmission mounts $50 each obo
AEM big brake kit $300
Racing Hart RacingHart cp 035 cp035 18" only 2 may have a 3rd one wheels $200 each
5 zigen wheel 18" $100
heater core with box $150
right side door power window actuator regulator assembly $50
Old Jan 29, 2009 | 06:51 AM
vtec718's Avatar
Default Re: fs type r itr parts whatever is left out of my wrecked itr
pm'd
Beasty18C5
Mar 13, 2012 03:25 PM
SOHC ON DIS
Texas -OK -LA (Sales)
18
Oct 8, 2011 06:29 PM
Beasty18C5
Oct 24, 2009 10:55 PM
powerfulperformance
Jul 28, 2007 11:24 AM
