D15 tranny to ZC engine?
Old Jan 28, 2009 | 07:59 PM
darkclark's Avatar
Default D15 tranny to ZC engine?
o own a 1990 honda civic with a ZC swap and crx si tranny and i was just wondering if a obd1 d15 tranny will bolt up to a zc engine?
what broke was were you put the cv shaft in is really loose would replacing that with a lsd fix my problem?
Old Jan 28, 2009 | 08:12 PM
ranom01's Avatar
Default Re: D15 tranny to ZC engine?
take the zc box apart and check that the diff hasnt broken any gears or anything inside, if its fine, swap out the brocken diff with a replacment one or a lsd and you will be sweet
Old Jan 28, 2009 | 08:18 PM
93formula's Avatar
yes it will bolt up, but if its a hydro trans then you will need a hydro clutch conversion kit.
Old Jan 28, 2009 | 09:43 PM
ef_junky's Avatar
and most likely your diff pin wore out and just crumbled and dropped all the spider gears if thats the case you can just replace it
Old Jan 29, 2009 | 06:00 PM
barely4dr's Avatar
it'll be fine unless the newer tranny is hydro
zorrobyte
10
Mar 11, 2013 11:08 PM
ekcid97
Apr 27, 2011 06:10 PM
mr_valentino20032000
11
Jun 5, 2004 04:18 PM
