new prostreet turbosystem
Old Jan 28, 2009 | 07:07 PM
NLR's Avatar
NLR
Default new prostreet turbosystem
Just some pics of a system Im building right now
Old Jan 28, 2009 | 07:12 PM
rip94delsol's Avatar
Default Re: new prostreet turbosystem
Good looking setup!
I have a brand new 3 1/2 wiggins clamp for sale.
Old Jan 28, 2009 | 07:27 PM
ToxicFabrication's Avatar
OG Fabricator
WOW thats a great looking fit!!!
Old Jan 28, 2009 | 07:52 PM
random_tuner's Avatar
Clean, I like.
Old Jan 28, 2009 | 09:36 PM
tony1's Avatar
As usual, looks like crap Seb. Stick with it though, you'll get better.
Old Jan 29, 2009 | 04:09 AM
m R g S r's Avatar
sick work man
why didn't you clock the turbo so the compressor outlet was facing the IC?
Old Jan 29, 2009 | 04:21 AM
NLR's Avatar
NLR
Tony,
Please come out to my place and invite some friends. I would like to see someone else play throw the hammer and fit that little SOB pipe from the turbo to intercooler LOL!!
Wheel and tire are the reasoning for the positioning of the turbo and pipe work. When I get it installed Ill show you.
thanks,
seb
Old Jan 29, 2009 | 07:43 AM
tractionwhat's Avatar
Originally Posted by m R g S r
sick work man
i was wondering that too but it looks like if he clocked it at that angle making the bend, it wouldn't flow as well. could be wrong tho.
looks great tho. diggin the aluminum welds.... real nice
Old Jan 29, 2009 | 09:05 AM
90blackcrx's Avatar
I'm sure 90% of the people on here can do a better job then that.... **** looks good though, nice transition from turbo to IC.
90blackcrx's Avatar
Originally Posted by NLR
Tony,
Sounds like a fun sex game, I'm in.
Old Jan 29, 2009 | 10:10 AM
miller's Avatar
Seb, you are out of your damn mind ridding a bike with that **** on it.
Can i ride it?
Old Jan 29, 2009 | 11:24 AM
m R g S r's Avatar
Tough crowd in here haha
Old Jan 29, 2009 | 11:37 AM
ABK's Avatar
ABK
I would clock the turbo so it faces the ic and get a shorter core so it doesn't get all heat soaked by the manifold (I think that would be way more effiecient), maybe make a heat shield of some sort. Looks nice but I would redo it. Is this seriously in a bike? Who ever is riding that is ****en suecidal.
Old Jan 29, 2009 | 12:05 PM
Mr. Danieli's Avatar
What type of welder do you have? Just curious if you use a pulse setting when welding alum and how you might have the pulse setting set?
Old Jan 29, 2009 | 01:09 PM
m R g S r's Avatar
pretty sure it's a drag only bike, so heat soak shouldn't be an issue like it is on a streetcar.
Old Jan 29, 2009 | 06:58 PM
NLR's Avatar
NLR
Im going to redo it. Then you can come over and help me figure out where we should relocate the front wheel too LOL!!
My last bike made 647 hp at 34 psi and its a 1.3 liter engine. Thats 497 hp per liter! At the end of the 1/4 mile my intake temps are at 135 on a 90 degree day using 25 psi of boost pressure. This is with using a fast response ptc sensor.
Old Jan 29, 2009 | 07:14 PM
eclypzex's Avatar
i love how you say it so casually....
its been asked before, but are you pulsing your welds? very consistant either way.. good work!
Old Jan 29, 2009 | 07:18 PM
dave@passenger's Avatar
Looks more like hes working/pumping the pedal.
Old Jan 29, 2009 | 07:47 PM
eclypzex's Avatar
basically the same thing? are there any drawbacks to pumping/pulsing?
Old Jan 30, 2009 | 03:45 AM
NLR's Avatar
NLR
Yes it is pulsed. 200hz, .5pps, 50% duty cycle, 42% final amps, 200 amps.
1/16 tungsten(red) 1/16 filler 6065
Old Jan 30, 2009 | 05:16 AM
tony1's Avatar
You could put some different forks on it to kick the wheel about 1' forward. lol
Old Jan 30, 2009 | 05:22 AM
weiRtech's Avatar
OG Fabricator
if this is a drag bike, i'm curious why you wouldn't go with an air to water i/c, or is there just not enough room for all the other components associated with an air to water setup? nice work btw.
Old Jan 30, 2009 | 05:36 AM
NLR's Avatar
NLR
that would defeat the whole point of bringing the front end in 1 inch from where it was LOL!!!
Old Jan 30, 2009 | 08:16 AM
Well for this application, which industrially we would refer to as ornamental, there isn't much of a draw back, because these parts aren't really subject to much stress or pressure. Plus its a lot easier to make pretty looking bead using a slow speed pulse or pumping the pedal. But for industrial applications it is a no no, reason being that those stacks of dimes, under each one is a little fish eye, they often turn into pinholes under pressure. Also the inconsistent penetration create stress risers in the reinforcement area which also leads to weld failure.
Old Jan 30, 2009 | 08:20 AM
Agtronic's Avatar
Absolutely perfect welding throughout. Awesome!
