89 honda Accord running rich
Old Jan 28, 2009 | 06:32 PM
eilyasjaan's Avatar
Default 89 honda Accord running rich
wut r the most ovious things that can cause an accord to run rich , my car comes up as a gross poluter during smog check but i cant figuare out y , thanks
Old Jan 28, 2009 | 07:30 PM
P_Adams's Avatar
Default Re: 89 honda Accord running rich
What model Accord?
Depending on what polutants you're dealing with...
1989 Accord LX Carbureted
Sinking Float
Dirty Needle & Seat
Misadjusted Choke mechanism
Inoperative Choke components
Leaking Vacuum hoses
Thermostat
EGR Valve
to name a few
1989 Accord LXi Fuel Injected
Leaking Fuel Injector
Oxygen Sensor
EGR Valve
MAP Sensor
Thermostat
Etc
P
Old Jan 30, 2009 | 09:32 PM
eilyasjaan's Avatar
sorry about that it is a 90 honda accord , not a 89 it is a typo
Old Jan 31, 2009 | 05:47 AM
P_Adams's Avatar
Same thing applies as the LXi
Oxygen Sensor
EGR Valve
MAP Sensor
Thermostat
Etc
P
Old Feb 4, 2009 | 05:28 AM
eilyasjaan's Avatar
so how do i test the problems , oh yeah my check engine light doesn't work , would that be the bulb or could it be some underline problem causing it to malfunction
Old Feb 4, 2009 | 10:29 AM
P_Adams's Avatar
Very little change that that bulb burned out by itself.
Does it temporarily light as you're turning the key to start?
P
Old Feb 5, 2009 | 07:23 PM
eilyasjaan's Avatar
when the car starts up they light doesnt come on , i didnt pass the california emissions test because fo thast so i am really wondering wut i should start out by doing first becasue i looked at the blub and it seems to be soldered into the circuit board , thank you for all ur help
shotoutacc0rd
Transmission & Drivetrain
12
Jul 28, 2014 05:50 PM
