Suspension & Brakes Theory, alignment, spring rates....
blox coilovers??
Old Jan 28, 2009 | 04:26 PM
poptart_ek4's Avatar
Default blox coilovers??
does anyone have them? has anyone heard about them? any info is helpfull thanks
Old Jan 28, 2009 | 04:50 PM
TrackSpeedRacing's Avatar
Default Re: blox coilovers??
Yea I have the Blox Drag Coilover 12k Front/18k Rear. 10K miles since installation. A little stiff for a daily driver, which is expected. I personally would recommend it to anyone thats in the market for a full coilover setup. The ones pictured below are the Tuner Series style.
Old Jan 29, 2009 | 10:07 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
1000 lb rear springs hahaha I'd like to see the dyno plot for that damper. Wonder if it can really withstand it, seeing as how a $500 set of OTS Koni dampers by themselves can only handle about 500-550 lb springs.
I would love to get a set of those dust boots if I were ever to put GC's back on my Koni shocks.
Old Jan 29, 2009 | 10:21 AM
cool thanks but are they damper adjustable
Old Jan 29, 2009 | 02:50 PM
xd69's Avatar
It doesnt matter how adjustable the dampening (im guessing rebound) is, it still doesnt change the maximum spring rate the shock can take
Old Jan 29, 2009 | 04:00 PM
Community Builder
You would think that since Blox slaps 18K springs on there that the dampers would be tuned to handle it (haha yeah right). I wouldn't expect any damper in that price range to handle springs that stiff.
Old Jan 29, 2009 | 04:08 PM
Mashimaro's Avatar
^ i do agree with you that i'd love to find a set of those dustboots
Old Jan 29, 2009 | 06:28 PM
beanbag's Avatar
What parts must be more expensive for a damper to handle higher spring rates?
Old Jan 29, 2009 | 06:42 PM
TunerN00b's Avatar
If (and its a big IF) linear damping is acceptable, then nothing should be expensive to have a shock designed for high spring rates (compared to the same linear damping but with lower values).
If you want a digressive curve, or want to be able to adjust the damping, then I would imagine that the cost of parts can go up quickly.
Don't Konis use a pop off valve to reduce damping as shaft velocity increases? Thats got to cost more than a simple hole in a shim.
Of course, one would also assume that hysteresis is reduced with superior shock internals, which (I would assume) would be more of an issue as rates (and damping) increase.
Old Jan 29, 2009 | 07:23 PM
Community Builder
Perhaps.... but do you really think the Blox dampers have different characteristics based on what springs they are shipped with?
Old Jan 31, 2009 | 03:21 AM
beanbag's Avatar
If you want a digressive curve, ... then I would imagine that the cost of parts can go up quickly.
Bilstein, at least, doesn't charge any more for a thicker shim.
You're comparing a twin tube foot valve design (on the compression stroke) to a monotube shimstack design. Neither get appreciably more expensive if you want to valve them for higher spring rates.
This may be true, although I don't know how they do it. In general, if you have less bleed (higher damping) you will have higher hysteresis anyway.
emooheo
Suspension & Brakes
Jun 27, 2010 03:52 PM
DC2_2
Oct 14, 2006 06:28 AM
VeilSide_Mas
Suspension & Brakes
Mar 27, 2006 10:00 AM
SAVAGE99
Oct 8, 2003 04:47 PM
citanest
13
Apr 12, 2002 02:53 PM
