rear mugen strut bar
my bar end pieces don't look like that, and the one end is adjustable. do i have the 1st gen model? and what did you use ot cut the panels? thanks again
I used a small saw and a dremel tool. I drilled the corners of my template when it was on the plastic, then used a dremel bit to cut straight down and along the lines of the template. It was pretty easy.
gen1 is ok on DC2... however, gen1 kicks major a$$ on EG and EK, as you can utilize 4 mounting pts per side.
thanks for the encouragement guys, i already put the front mugen bar on and it is solid, but now i feel more understeer, well time for bigger sway too.
So, I put back OEM ITR front strut bar + Mugen rear bar and it allows for better balance and ready throttle lift oversteer with right condition.
Ultimately, Mugen sway bars 24mm (or even JDM 23 (?) mm rear sway) would be the best with Mugen strut bars, IMO.
. on my want list, which grows buy the day cause i have no $$$ for mods. still spending my $$$ on HPDE's
skafia
16
Nov 16, 2002 02:40 PM
