my honda doesnt start
Old Jan 28, 2009 | 10:05 AM
joefrey50's Avatar
Default my honda doesnt start
I replaced the head gasket on my 96 accord because the gasket had a cracked between 3 and 4. put it all back together and it doesnt start. I check all the normal things. It has injector pulse, fuel pressure, good compression and spark. I tested the coil and the distributor(icm) and found no problems. Any ideas will help!
Old Jan 28, 2009 | 10:10 AM
P_Adams's Avatar
Default Re: my honda doesnt start
Cranks but won't start? or
Won't crank. (period)?
Camshaft / Timing 180 degrees off?
You should (at least) pull the upper belt cover and confirm everything's phased correctly.
P
Old Jan 28, 2009 | 10:15 AM
joefrey50's Avatar
It cranks a good stron crank. I triple checked the timing. It has 165 on compression. It has injector pulse on all of the injectors.
Old Jan 28, 2009 | 04:57 PM
joefrey50's Avatar
I also tested the main relay and it test out good. WTF! Why wont it start! does anyone have any other ideas? It has everything it needs to start! PLEASE HELP!!!!!!!!!!!!!
Old Jan 28, 2009 | 05:09 PM
philafelman's Avatar
possible cylinder wash....try a couple drops of oil in each cylinder.
Old Jan 28, 2009 | 05:17 PM
joefrey50's Avatar
You want me to try that even if i have 165 compression?
Old Jan 28, 2009 | 05:18 PM
if you say you have spark and fuel, compression or timing could be the only options....recheck your timing.
Old Jan 28, 2009 | 05:21 PM
joefrey50's Avatar
What about pcm?
Old Jan 28, 2009 | 05:23 PM
its possible, but if it ran before the repairs its unlikely....double check for spark, fuel, compression, and timing.
Old Jan 28, 2009 | 05:29 PM
joefrey50's Avatar
I tested the coil and the resistance was with in specs. I tryed another distributor i had and that wasnt it. The spark is a bright blue color. Compression is 165 and i have had 3 other mechanic friends look at it and they said the timing is perfect. Im so frustrated with this car!!!!!!!!
Old Jan 28, 2009 | 05:47 PM
can you take pics of the timing on the cam/crank? did you test for spark at the spark plug, and what was ur fuel pressure?
Old Jan 28, 2009 | 07:27 PM
joefrey50's Avatar
I am 100% that the timing is on. I have access to alldata and also had a couple of my mechanic friends come and look at it and they said it is dead on. Fuel is at 39 psi. Has injector pulse on all injectors. Has spark. double checked and triple checked all items. Im thinking it might be the pcm. Anymore iteas other than pcm?
Old Jan 29, 2009 | 07:20 AM
craiger28's Avatar
If it was the pcm would it still have spark at the plug??? How hot did it get when it overheated? I had a toyota camry get really really hot and it would not start after it was fixed, until I had the entire wire harness in the engine bay replaced. Just something to think about. Timing being off 180 degrees would be my next guess but you state it is on perfect. Your have fuel and you have spark and 165 psi compression. Man what else could it be?
Jakester9500
Mar 20, 2017 06:54 AM
chad olson
Jan 13, 2009 09:30 AM
mooneybeams
Jan 11, 2009 04:40 PM
Dogman_1969
Jan 3, 2009 05:22 AM
