Faulty Coolant Temp sensor= hard starting?
Would a faulty coolant temp sensor cause my CRX Si to have a hard time with cold starting? I have heard people claim this and i am confused as to why that may be. I was thinking that the reason to my starting issue would be more likely due to an old/faulty fpr (i say this b/c i have replaced the fuel pump and strainer, filter, and have replaced fuel injector gaskets). Why would someone assume a faulty coolant temp sensor rather than fuel delivery components? If the sensor were broken would the gauge on the cluster stop working? etc. Any help will be appreciated. Thx
I don't think it would have anything to do with the CTS. How's your battery that can make it have hard starts in the cold, also the cold can make it turn over slowly depending on the compression in the cylinders. The cold period just makes cars work like ****.
absolutely, the CTS changes resistance depending on temperature of coolant, sending information back to the ECU giving it the information needed for the engine to run properly.
I know the cts can make it run rough, it just doesn't seem very likely that it would be the cause of a hard start. I could be wrong though, whatever, good luck either way.
aznjay510
Aug 29, 2009 12:18 PM
puertoricanboy90
Jan 28, 2009 10:03 AM
vtecaccord 1
Dec 7, 2004 05:59 AM
