ls/vtec help
Old Jan 28, 2009 | 09:34 AM
sirt_eg's Avatar
Default ls/vtec help
Build high compression ls/vtec. First thing I have trouble.
1. When I start the car, it starts, than dies. When I hold on the gas pedal until it's warm enough the car's idle fines. Loose vacuum? Check all the vacuum and everything seems fine. Any suggestion?
2. After checking my spark plug, it was dark. carbon build up I'm guessing. timing?
3. The rpm flutters when I drive past 2.5k-3k rpm.
4. When trying to speed up and stepping down on the gas pedal the car studder and feels like it has no power than drives fine after a certain point.
Any help will be great.
The ecu is chip with a ls/vtec high compression. Still need to be tune.
Old Jan 28, 2009 | 09:37 AM
z6hatchboy's Avatar
Default Re: ls/vtec help
check the timing possibly, and cels?
Old Feb 1, 2009 | 06:05 PM
sirt_eg's Avatar
bump, Thats my suggestion too, dont have time to do timing but the timing belt is getting rub on by something cause the side is peeling off.
Old Feb 1, 2009 | 07:23 PM
looseOFFboost's Avatar
i wuld do a compression check to make sure your timing is right and everything is mechanically sound. check ignition timing and if it still acts up get it tuned. your chip isnt tuned to your car specific. Or try another ecu with the chip or another high compression chip.
Old Feb 2, 2009 | 07:45 PM
sirt_eg's Avatar
did compression test. Came up 215/215/200/200. No CEL. maybe I'll just go get it tune and check out at kings.
808DB1
Mar 15, 2008 09:44 AM
Samuels
May 26, 2007 08:34 PM
kevlh18
18
Jan 20, 2006 04:43 PM
bushfreakz
Jul 17, 2003 03:21 PM
