What e-brake cables for 88' HF rear disc conversion?
Hello,
Did a little searching and read the FAQ's but cannot find anything specific to the 88' HF on this (may be missing it tho).
I just completed a rear disc conversion including the entire setup (rear trailing arms, compensator arms and upper, lower arms together). This was from a JDM car (believe it was a SiR). Since the swap was assembled I attemptd to use the e-brake cables and they seem to be 6-7" too long.
Which cables would be a direct fit replacement? BTW the car will roll even in gear so I'm being overly cautious until this is fixed.
Thanks,
-Mike.
Thanks,
-Mike.
Lokar makes a nice adjustable length (cut to length) e-brake cable. In stainless steel and black vinyl. The stainless is ~$165. The black ~$100. I have used them twice for WIlwood rear disks. You have to use their kit, everything is included.
lsvtecrx
22
Nov 8, 2002 02:02 AM
