B16 ECU Chip Suggestions
No need to write paragraphs about this..
I'm not looking into buying something from Hondata, converting obd 0 - 1 new distributor and so on..
I've heard of many different companies but I obviously have no prior experience
** What ECU CHIP would you reccomend for a PR-3 OBD-0 ECU / b16a w/ slight mods ? **
AND - PLEASE LINK ME OR DIRECT ME WHERE TO PURCHASE
Thanks,
Thanks,
since you have an obd0 ecu you're limited with tuning options. about the only thing you can do is get it chipped and have it tuned with turboedit. but trying to find a place who can tune with turboedit may prove difficult. an ebay "moo-gen" chip isn't going to cut it. You cant just drop in a chip and go. every engine is different and generic basemaps that dump extra fuel won't make your engine run better. honestly even if you get it tuned you probably won't make that much more power than you are now. with light mods the stock ecu is more than capable of compensating and getting you the most power. if you had different cams or something then having it tuned would make more sense.
BRE is the only option for obd0 ecu's. There hasn't been much support for it lately but the last version works pretty well.
http://ef-honda.com/ben/bre/maindoc/index.html
