Stock tach off by 500 RPM.
Old Jan 27, 2009 | 08:57 PM
chwkef's Avatar
Default Stock tach off by 500 RPM.
I have a 1990 EF with a B18A1. Recently bought it.
It has a big ugly Autometer tach and shift light screwed to the gauge cluster surround. I want to remove and sell the tach and shift light, but the stock tach is not accurate.
The stock tach (My car is a DX with an SI interior) is always off by 500 rpm. So if I ditch the Autometer I won't have an accurate tachometer anymore. Is there any particular fix to this?
Thanks guys
-Dirk
Old Jan 27, 2009 | 09:11 PM
KRock459's Avatar
Default Re: Stock tach off by 500 RPM.
Did someone remove and reinstall the needle? If they had ever been removed for paint or any gauge work, they can get installed wrong. You can re-index it using your second tach unit.....if you trust that
Kirk R
Old Jan 27, 2009 | 09:16 PM
ef_junky's Avatar
i had the same problem in my four door when i took the tach out it seemed to be more accurate i think its cause they wired it into the back of the factory one through the harness.....
Old Jan 27, 2009 | 09:53 PM
chwkef's Avatar
Hmmm, ok well I"ll take out the Autometer and see what happens. It could be because it tapped into the factory harness.
I know the tach was exactly 500 off b/c I checked it with a digital timing light.
Thanks guys,
Dirk
Old Jan 27, 2009 | 10:29 PM
C_R_X_V_T_E_C's Avatar
maybe your autometer tach is off.... think of that?
mabe your tach signal is weak
you have your tach signal wire spliced into the green wire at the distrubutor?
Old Jan 28, 2009 | 01:31 AM
NlCK B's Avatar
is your mph off as well i had a similar problem with my swap it was just beacuse i had a different roll out
best way to check if your mph is off is pull up next to a new civic on the freeway and passe him then look at his huge speedometer with the big numbers and compare to yours
Old Jan 28, 2009 | 07:23 AM
chwkef's Avatar
Read much? I'm not sure exactly where it's spliced in b/c like I said, I just bought the car. I'll look into it when I go to take it out. My mph (km/h up here ) seems to be accurate
Old Jan 28, 2009 | 12:04 PM
Read much?
i hope you spontaineously combust
Old Jan 28, 2009 | 01:10 PM
mike93eh2's Avatar
lol at all the replies.. all factory honda tachs are off by about 500 rpms. they made it that way.
Old Jan 28, 2009 | 02:02 PM
allgo88's Avatar
no way.ive had my factory tach,an autometer,and my vafc all going at the same time.they might have been 100-200 off.the autometer is much quicker,but definitely not off 500rpm.
Old Jan 28, 2009 | 02:17 PM
xci_ed6's Avatar
The OEM tach is more of a guesstimate, always will be.
Old Jan 28, 2009 | 02:21 PM
mike93eh2's Avatar
its more at higher rpms.. sorry you had to find this out.
Old Jan 28, 2009 | 03:26 PM
allgo88's Avatar
my cel shift light is set a 7600,and its in time with my tach.mabe the guys pushing 9g are off more.
Old Jan 28, 2009 | 07:40 PM
fltblkEFhatch's Avatar
if is is constantly off by 500 (idling at like 0) you just need a new cluster, the same thing happened to my 91 dx hatch with the crx si dash and cluster, i replaced it with a si hatch cluster from the local j/y and it works fine now.
Old Jan 28, 2009 | 10:11 PM
dcvt16's Avatar
thats funny, i do that everytime i see one. lol
Old Jan 28, 2009 | 10:13 PM
aasarsak's Avatar
I agree, but 500rpm does seem like quite a bit. Have you checked all your grounds?
chwkef's Avatar
Working on it haha
Thanks for all the help guys. I'll take out the Autometer anyways and If that doesn't fix it, get a new cluster. I need a new surround anyways since the previous owner used wood screws to hold the tach and shift light down. And If I get another cluster I'm doing a DC cluster swap.
-Dirk
SFlCrx
Sep 12, 2006 03:46 PM
JuggerNuts
Jun 18, 2006 07:35 PM
Dropped90Integra
Feb 1, 2005 07:21 AM
Skunk_it
Sep 10, 2002 04:41 PM
