96 del sol S - prop valve?
Doing a rear disc swap.
Actually i'm putting LS brakes all the way around...
I purchased a 4040 prop valve, but it looks exactly like the one already on my car.
Anyone know the size of the one thats stock for my car?
Some of the brake line bolts are corroded to hell, so I'm wondering if I can use the same one?
You are not going to be able to tell anything from the size of the unit it will look the same the only way to tell is what the part number is on the prop valve
part# for the 4040 valve is 46210-SR3-962
part# for the Delsol S is 46210-SR2-A01
on the valve there is a number if you look closely you can see it. i believe the ones on the s model were 1725 just look for the 4 digit number and that should tell you heres a pic for reference
Alright cool, so its safe to assume they are indeed different and I need to suck less and get some of these stuipd *** bolts out -.-
snowboarderguy44
Nov 14, 2003 09:23 AM
