what is relays near passenger headlight?
Old Jan 27, 2009 | 07:13 PM
bobbyisking's Avatar
Default what is relays near passenger headlight?
i just finished dropping in a b18a into my 88 crx dx. will not be running ac. as i was trying to clean up some wires, i noticed the relays near the passenger side headlight. the three right on top of it near the radiator. i'm assuming they are a/c related. also, how would i determine what plug harness to cut off/hide to keep everything nice and clean, other than whatever is left after plugging everything in once i finish the swap? i'm just waiting for my harness to arrive so i can finish converting to mpfi and plug everything in.
Old Jan 27, 2009 | 07:56 PM
xileap2's Avatar
Default Re: what is relays near passenger headlight?
disconnect the a/c fan and follow it all the way and you'll notice which other one belongs to the a/c
Old Jan 27, 2009 | 10:26 PM
Clipsed's Avatar
AC harness is completely separate from your engine/headlight harness. You can directly disconnect it under the dash which I think is 3 connectors and pull it from the engine bay and keep it intact and save it, or sell it for $10 to someone who needs it.
Old Jan 27, 2009 | 10:48 PM
01-0041's Avatar
Fan relay as the A/C harness is separate from the main harness...
Mike Bonifant
Dec 29, 2014 07:40 PM
jasoncanseeoh
Feb 9, 2010 07:28 AM
jasoncanseeoh
Feb 9, 2010 12:14 AM
Stoich
Jun 9, 2005 11:14 AM
_Spugen_
Jul 25, 2004 12:43 PM
