GA FS: COMPLETE 96 GSR SWAP! Everything that you need!
$2400 OBO
Up for grabs is a 1996 COMPLETE GSR Swap/Changeover. In short this car has lived its life under a middle aged woman. This car has maybe seen Vtec engagement twice in its life (exaggeration but you get the picture). My mom gave me her 96 GSR a few months back and now I have decided to go K Series so I no longer need this swap, HOWEVER if no one buys this awesome deal I will just go ahead and rebuild it and put it back into the car. My mom I believe still has a HUGE portfolio of all the maintenance that was done to the car/motor mostly all from the Acura dealership that I will provide to the buyer if they want it.
Also the ONLY I mean ONLY reason for the after market intake and header was due to the stock air filter needed replacing and I had the intake lying around and the stock header had a crack in the casting and I had the header lying around (Scouts honor!) other wise car is as stock as they come.
The only thing this motor will need is an oil pan gasket which I will throw in a new one with the purchase.
VIN: JH4DC2389TS000463
Block Code: 3300570
Mileage: 186,369.2
You will receive the following parts:
-Complete Motor and Tranny
-All motor mounts and brackets
-Engine Wiring Harness
-Shift Linkage
-New Axles
-Stock P72 ECU
-Alternator
-PS Pump
-AC compressor
-Distributor
-4-1 Header
-Akimoto/AEM Intake
-All sensors etc.
Swap is located in Columbus, GA and i will be willing to deliver it to your door, Call or Text 706-577-3364 Ray
Block Code: 3300570
Mileage: 186,369.2
-Shift Linkage
-New Axles
-Stock P72 ECU
-Alternator
-PS Pump
-AC compressor
-Distributor
-4-1 Header
-Akimoto/AEM Intake
-All sensors etc.
eternal780
Aug 27, 2006 11:12 PM
