AC compressor cycling on/off
My ac compressor continues to cycle on when ever I have the blower motor on. Its rather cold out here in Virginia so as you'd assume I have the heat on. Only to look down and the AC button will be illuminated and I can tell the compressor is cycling. If I try to press the AC button to shut it off it does nothing,at least for a solid minute or two.
I have not checked the freon pressure yet,im going to do that tomorrow just wanted to get a head start on other possible issues that could cause this.
Have you tried this? https://honda-tech.com/forums/showthread.php?t=2485503
Thanks for the override link!
Civic Racer X 7
Aug 8, 2007 05:15 PM
