Accord Ex 1993 CO & NO level- Auto 190k
Old Jan 27, 2009 | 11:32 AM
zspy_007's Avatar
Default Accord Ex 1993 CO & NO level- Auto 190k
Hello all,
What causes the CO & NO level in my accord to be so high?
Readings were almost double the limits.
I noticed the car has what it looks like an off road catalytic converter.
Could it be the cause?
you help is greatly appreciated.
Also, I found an old catalytic converter (honda). If I look through the front end toward the back end, I only see the light in about < 0.5" diameter. What i am trying to say is the opening on the converter is about 1.5" in diameter. Is this converter clogged?
Thank you
Old Jan 27, 2009 | 05:36 PM
zspy_007's Avatar
Default Re: Accord Ex 1993 CO & NO level- Auto 190k
anyone??
Old Jan 27, 2009 | 06:41 PM
P_Adams's Avatar
Originally Posted by zspy_007
Hello all,
Thank you
The o2 sensor can have adverse effects on the CO and NOx levels (both the element part, but the heater as well)
Reference Material:
http://www.autohausaz.com/honda-auto-parts/honda-emissions-oxygen-sensors.html
In addition, High NOx can also be caused by anything which increases Combustion Chamber tempuratures. Like:
Vacuum leaks
Insufficient EGR operation
Clogged EGR ports
In addition, read this:
http://www.asashop.org/autoinc/oct2004/techtips.htm
P
blue 90 accord
Dec 23, 2018 09:34 AM
fen-x
Jul 15, 2013 11:58 AM
nickohlassss
Dec 7, 2008 06:32 PM
PandaBear
Acura TSX
56
May 12, 2005 04:23 PM
FrostyDC4
Oct 12, 2001 12:40 PM
