91 crx si ls swap
Old Jan 27, 2009 | 01:10 AM
J(ake)DM's Avatar
Default 91 crx si ls swap
i have an 91 crx si i just swapped a b18a1 in it i have double checked everything and i can't get it to crank any advice will work please and thank you
Old Jan 27, 2009 | 06:00 AM
lilsicsoul's Avatar
Default Re: 91 crx si ls swap
Check your grounds...
The wire harness ground..
Goes nex to the thermostat on the back of the block
Motor ground..
Its the wire on the valve cover on the front of the the motor drivers side.
Tranny ground
Wire comes from the wall to the tranny..passanger side
And what should of been the first
STArter ground wire...
Skinny black wire that falls off once in the blue..
Old Jan 27, 2009 | 10:16 AM
txihondatec's Avatar
Motor ground..
Tranny ground
good info,i'm goin through the same issue with my ls
Old Jan 27, 2009 | 10:53 AM
sgallagher's Avatar
Thats not a ground wire, its the starter signal wire from the ignition.
Starter grounds through the case.
Sounds like a ground issue for sure though. If you painted any brackets(i.e clutch cable) make sure the surface where the ground attaches is free of paint.
djrubio
Southern California
Jun 26, 2010 02:42 AM
dj-t
Sep 26, 2007 04:04 PM
BigDawwg6969
Feb 20, 2006 12:14 PM
VRD^don
Apr 13, 2005 04:16 PM
WuShu
Aug 18, 2001 12:14 AM
