How to get dome light to work with aftermarket headunit
Old Aug 7, 2002 | 01:19 PM
OptimusPrime2k's Avatar
Default How to get dome light to work with aftermarket headunit
Can anyone tell me what wires i have to splice in order to have my domelight work with my aftermarket headunit?
Default Re: How to get dome light to work with aftermarket headunit (OptimusPrime2k)
by the way its a 97 civic hx
Old Aug 7, 2002 | 01:40 PM
I-Am-Chris's Avatar
um I didnt know u had to do that. I had to run a wire to the battery so my memory would stay in a 92 SI
Old Aug 7, 2002 | 02:57 PM
EKB18BPR3's Avatar
WTF? what u mean headunit to work with dome lite? explain better and we'll try to help u better
Old Aug 7, 2002 | 03:05 PM
loki2323's Avatar
Default Re: How to get dome light to work with aftermarket headunit (dniedacess)
he's talking about the fact that if you replace a stock and dont keep the stock head unit in the car...you will loose your dome light and also if you have the stock keyless entry, that wont work anymore either.....
you have to wire the new headunit into the car and at the same time keep the stock unit connected to a power source...I have mine burried behind where the radio normally sits...its all screwed down and isnt in the way of anything
do a search on yahoo for honda civic radio install.....I remember there being a few good sites that give you step by step instructions on how to wire it all up...hope this helps...............
Old Aug 7, 2002 | 03:30 PM
TurboBumblBee's Avatar
Default Re: How to get dome light to work with aftermarket headunit (loki2323)
Yes he is correct, im a car stereo installer at circuit city, there is a harness that we sell that will allow you to wire the stock radio up to the aftermarket and tuck the stock unit behind the dash.. it works perfectly and you keep the keyless entry and domelight it fits back there w/ no problems at all. the kit only costs about $20 bux and is plug and play.. good luck
Old Aug 8, 2002 | 06:44 AM
Default Re: How to get dome light to work with aftermarket headunit (95CivicEX)
thanks guys, it pissed me off when i found out it didnt work.....at least i can fix it now
Old Aug 8, 2002 | 07:17 AM
RSZero1's Avatar
Really interesting...I have a 97 HX and an Alpine radio. No problems with my dome. I don't have the keyless entry tho. And as far as I know, I have my old stock radio in my storage room.
Old Aug 8, 2002 | 07:27 AM
Default Re: How to get dome light to work with aftermarket headunit (RSZero1)
if the car didnt have keyless entry you will not have any problems w/ the dome light unless the person who installed the alpine unit rewired the domelight..
Old Aug 8, 2002 | 09:44 AM
StevenTran305's Avatar
I remember I installed an aftermarket head unit in his old *** toyota and the dome light, the alarm, and the head unit didn't work, so I just redo all the wirings and retaped all the wires carefully and hey what did you kno? Head unit, dome light, and alarm worked. I dont kno what I did,but it worked.
Old Aug 8, 2002 | 09:48 AM
Default Re: How to get dome light to work with aftermarket headunit (StevenTran305)
I remember I installed an aftermarket head unit in his old *** toyota.
I was refering to a friend of mine. sorry for the mistake
Old Aug 8, 2002 | 09:06 PM
ef ect's Avatar
no you do not have to leave the radio in the car to get the dome light to work if you do this it a pain in the a$$ for nothing. If you have keless then never mind this but on the back of the radio is the little harness that dosent have speakers and such in it(the small green one i beleive), all you need to do is tap the seafoam green and red and seafoam green and black wires together at least i think those are the colors better check, anywhay tape them together and wala dome light withe doors.
Old Aug 13, 2004 | 03:53 PM
quagabow's Avatar
Default Re: How to get dome light to work with aftermarket headunit (ef ect)
yeah in my 97 hx (w/o keyless entry) i just jumped the two wires (green/red and green/black) with a paper clip and it worked perfectly. If u want a pic of the harness with the clip bent in it or directions on what to do just PM me or AIM me...sn is same as h-t name.
Old Aug 13, 2004 | 04:35 PM
skrewdriver88's Avatar
Default Re: How to get dome light to work with aftermarket headunit (quagabow)
I have a 97 HX also and my dome light doesn't work but i like it like that. But yeah its not hard to fix it. The installer should of done it for you for no extra cost.
Old Aug 14, 2004 | 01:39 PM
quagabow's Avatar
Default Re: How to get dome light to work with aftermarket headunit (skrewdriver88)
i hated not havin a dome light at night...and can't u just turn it off with the switch so it doesn't work when the door is open from the top if you wanted to? Yeah i was the installer of my stereo and didn't know about that stupid dome light thing til after i put my car back together and read about it online. stupid honda integrated security.
Old Aug 14, 2004 | 02:59 PM
jeffk182's Avatar
I forget which colors, but u have to cut 2 wires and splice them together. I'll try to get back to you on that.
dedehonda
Audio / Security / Video
Mar 11, 2015 09:33 AM
genner
Feb 19, 2013 08:05 PM
youhellacoo
Oct 20, 2008 12:34 PM
macson
Jan 19, 2008 12:34 PM
goodfella732
12
Jul 25, 2002 06:42 AM
