Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Ksport issues with tie rod ends?
Old Jan 26, 2009 | 08:59 PM
project dc2's Avatar
Default Ksport issues with tie rod ends?
anyone here have K-sports or function forms and have issues with busting the steering rod ends ? my buddies been running k-sports on his civic for a while and the tie rod ends keep busting causing a horrible clicking noise when driving and front end vibration. any fixes or ideas to this ?
Old Jan 27, 2009 | 05:28 AM
homelessEm2's Avatar
Default Re: Ksport issues with tie rod ends?
ill tell you now the reason he is busting them is more than likely attributed to the angle of his tie rod ends. the inners are probably pointing to the moon and the outers are binding up when he turns hard and since they are cast they are the weak link. you can do one of 2 things.
1: buy the T1R inverted end. i think they are junk and they dry out and make noise then eventually break anyway.
2: you can flip your existing tie rod ends and hone out the arm on the coil over. that's the route i went and i have had great success since doing this. OEM units are stronger i feel and i have corrected my bump steer as well by doing this.
Old Jan 27, 2009 | 07:14 AM
Harlowe's Avatar
Function>Fashion
You flipped your stock tie rod ends? I was thinking about this, but I wasn't sure if there would be any issues. I guess the tie rod end nut on the strut stays nice and tight?
Old Jan 27, 2009 | 07:16 AM
hone out/ mill where the arm hits the coilover ? or hone out where the coilover and the shaft of the tie rod sit ?
Old Jan 27, 2009 | 08:36 AM
harlowe, i havent had an issue with this since the install. i did it with a Titanium step bit in a reg. ol' drill. so now instead of having a taper goin top to bottom big to small its more like a hour glass shapp so if i ever had to go back or anything like that i could and it would still hold. i recommend getting a nice heavy duty washer for up top now and snug it up like normal then a good cotter pin
project dc2, heres a lil diagram that i stole from crsx and used to explain my mod.
heres some pix of the mod done and the success rate...http://forums.clubrsx.com/showthread...ht=diy+tie+rod
Old Jan 27, 2009 | 09:04 AM
Harlowe's Avatar
Function>Fashion
Very cool, I think I will have to do this very soon!
Old Jan 27, 2009 | 09:26 AM
night and day difference when i did mine. my angles were so bad due to the drop i have, after doing this my tie rods are flatter and more level than most every 7thgen Ive come across at stock height. (rsx, Si or civic)
Old Jan 27, 2009 | 11:31 AM
you get realigned afterward ?
Old Jan 27, 2009 | 03:36 PM
yea you have to cuz your spinning the outer tie rods in
Old Jan 27, 2009 | 04:25 PM
katzenjammer84's Avatar
Not to discredit homelessEM2, but I've been running my T1R inverted rods for over a year with 15,000 miles put on them and no problems.
Old Jan 27, 2009 | 08:47 PM
are they the newer ones with the zerk fittings or w/o? cause i know from the mini truckin that the heim ends that are w/o the fittings will eventually wear out due to the fact that you cant grease them. this results in noise and failure. like when a ball joint goes bad and has play. i just prefer the stock ball joints to a heim (swivel) end.
the 2 factors that come to mind are the amount of articulation/how low are you. this would determine the amount of stress and movement on the T1r type units also dictating how long they will last. and the other would be personal preference i guess.
Vagitarian
Feb 20, 2014 05:19 PM
decode33
Honda CR-V & Element
Oct 22, 2011 11:06 PM
1badcrx
Nov 30, 2010 07:27 PM
k20eklipse
Suspension & Brakes
Oct 27, 2010 03:57 PM
yOnKiNaToR
May 17, 2005 11:46 AM
