dx to si guage cluster
Old Jan 26, 2009 | 07:54 PM
builtsinglecam's Avatar
Default dx to si guage cluster
how hard is it to convert the dx cluster to an si one because of the rpm on it, and how much wiring?
Old Jan 26, 2009 | 08:25 PM
Default Re: dx to si guage cluster
anyone?
Old Jan 26, 2009 | 08:26 PM
DustinatorEK's Avatar
its plug and play... Wire the Si one up the same as the Dx. And tach will work
it takes the existing wireing. i belive its 2 or 3 plugs
Old Jan 26, 2009 | 08:28 PM
Deetz's Avatar
Crazy Honda Guy
10 minute job, plug and play
Old Jan 26, 2009 | 08:35 PM
thankx yall
Old Jan 26, 2009 | 09:00 PM
Targa250R's Avatar
be professional
Keep in mind that wiring incompatibilities exist between model years. What year/model is your car, and what year/model have you pulled a gauge cluster from?
All '90-91 clusters are interchangeable and will plug-and-play, but '88-89 clusters have a number of differences.
Old Jan 27, 2009 | 07:32 AM
miamiboy91's Avatar
how high is the rpm's on an si cluster?
Old Jan 27, 2009 | 08:18 AM
ciiivic89's Avatar
i have an 89 si and i want to swap it out with an 90 si will that work?
Old Jan 27, 2009 | 09:22 AM
Targa250R's Avatar
be professional
With exception of the CRX HF, all USDM '88-91 Civic/CRX tachometers are the same: 6500 RPM redline, 8000 RPM maximum reading. The HF has a 5000 RPM redline but the same 8000 RPM maximum.
It won't plug and play.
You'll have to change the cluster hood, the rheostat, hazard and defroster switches to make it physically fit, and you'll have to re-wire the plugs to make it function. I believe you also need to cut the actual plugs from the donor's harness.
Old Jan 27, 2009 | 12:00 PM
redlobster's Avatar
i have an 89 hatch dx, and looking at putting a cluster from an 88 crx, it will just plug and play right?
Old Jan 27, 2009 | 01:10 PM
hondafab19's Avatar
it might plug and play ... but the crx cluster is smaller
and deeper than the civic one, which means it wont fit.
Old Jan 27, 2009 | 01:12 PM
Radim's Avatar
I have a 89 CRX SI Cluster on my 89 STD Hatch
Old Jan 27, 2009 | 01:25 PM
hondafab19's Avatar
wow didnt think they fit, but i guess they do..
Old Jan 27, 2009 | 02:11 PM
ryanevansoh's Avatar
yup crx ones fit the same
civicb16eg
Jun 26, 2008 07:37 AM
rxmx
23
Jan 15, 2007 07:23 AM
89sicivic
May 25, 2006 10:43 AM
608 Gangsta
12
Jun 12, 2004 06:04 AM
buckNasty
Oct 11, 2003 06:57 PM
