"Grinding" noise
Old Jan 26, 2009 | 03:41 PM
hfsfan928's Avatar
Default "Grinding" noise
1990 CRX Si, for a while now there's been a noticable grinding sort of noise when I'm driving around, primarily in first and second gear. It shifts fine and everything, it's just the noise. Originally I was told it was the throwout bearing, but a friend also said it could be my transmission fluid... Except it's a manual, I'm not sure how to check my tranny fluid. Someone else said something about my slave cylinder? I'm so lost.
Old Jan 26, 2009 | 04:03 PM
ef_junky's Avatar
Default Re: "Grinding" noise
well you can look on the passenger side of your tranny and the will be two bolts one that takes a 17mm by the axle and the other at the bottom it takes like a 3/8 drive rachet you can take it off and drain it then fill it through the top one till it starts to pour out then its full i'm pretty sure you can use 10w/30 motor oil
Old Jan 26, 2009 | 04:08 PM
hfsfan928's Avatar
Thanks... I'll try that when it's not so dark out and I can actually see what I'm doing.
slowslow
Apr 22, 2009 08:37 PM
eluam
May 18, 2008 10:39 AM
Cypher0117
24
Apr 17, 2005 07:11 PM
tur3oDC4
Nov 25, 2004 11:05 AM
01-1293
Jul 12, 2002 11:11 AM
