Mid-Atlantic (Sales) VA, DC, and MD
peerless TV mount plasma/lcd x2 250$ ea
Old Jan 26, 2009 | 01:09 PM
EK FLY's Avatar
Default peerless TV mount plasma/lcd x2 250$ ea
he SmartMount® Pull-Out Swivel Wall Mount combines the best features of a wall mount and a pivot arm. In the closed position, the SP850 acts as a flat or tilting wall mount. At only 2.25" away from the wall, its unique wall plate and built-in cable management neatly hide all components and cords. Extended, the SP850’s sturdy arm construction smoothly glides the screen out 10.75" from the wall and allows the screen to pivot up to 45 degrees. This feature not only enables the screen to be positioned for an optimal viewing angle, but it also provides easy access to the back of the screen for maintenance. The SP850 is also ideal in applications where the screen needs to be recessed into a cubby hole, custom frame or aligned into a video wall. Mounts to 16" wood studs, concrete or cinder block.
http://www.peerlessmounts.com/dyn/Pr...oryID/195#more
retail cost of this mount is 376$+ shipping this a very expensive mount i have 2 of them I will let go for 250 each , all sealed up never been used or open
SpoonMe
16
Aug 26, 2003 08:53 AM
shamun
Jul 13, 2001 02:57 PM
