Wheel Spacers
Old Jan 26, 2009 | 01:07 PM
josh's ep3's Avatar
Function > Form
Default Wheel Spacers
Hi guys, I was wondering if anyone knew if I would need to get extended wheel studs if I ran 10mm wheel spacers? I've seen both answers and I want someone that knows for sure, thanks guys.
Old Jan 26, 2009 | 01:46 PM
blackk20dc5's Avatar
Default Re: Wheel Spacers
i heard you dont have to but you should just get the h and r ones that have the studs right on the spacer
Old Jan 26, 2009 | 01:53 PM
Type-Spaz's Avatar
DC5/EP3 MOD :)
for 10mm you can get away without them.
but FYI extended wheel studs are so damn sexy I would keep it in consideration
Old Jan 26, 2009 | 01:54 PM
would that mean you have to run open lugs
Old Jan 26, 2009 | 02:03 PM
what if i wanted to run 25mm on stock tire..would i rub
Old Jan 26, 2009 | 05:18 PM
katzenjammer84's Avatar
On non Si Civics the limit is 5mm w/o extended studs, I'd be surprised if 10mm was able to work on Si's given such similar suspension component design.
Old Jan 26, 2009 | 06:34 PM
josh's ep3's Avatar
Function > Form
Damn, I might just get the studs anyway, just to be safe.
I thinks stock wheels are like +40 offset so 25mm spacers would be like running +15 offset wheels. I have +25 wheels and I rub in the back sometimes but I don't have rolled fenders, so blackk20dc5 you prolly could make it work but with a fender roll.
Old Jan 26, 2009 | 06:44 PM
DaveSi677's Avatar
Studs just look hot!!!!
Old Jan 27, 2009 | 12:55 AM
Dann6968's Avatar
I would just get the extended studs. My brother and a buddie have both had their studs break with a 10mm spacer and stock studs. My brother was going slow so very little damage but my buddie ****ed up his whole rear fender.
Play safe.
Old Jan 27, 2009 | 05:08 AM
josh's ep3's Avatar
Function > Form
Yepp, definitely getting them now haha. Pros out weighs Cons, Pros: They're stronger, they look dope, I'll be able to run whatever spacers I want... Cons: They don't install themselves.... Ok, I'm sold, thanks guys!
Old Jan 27, 2009 | 09:56 PM
is your car stock height? because right now im at stock and im getting coilovers so i could lower it just enough so they dont rub... or just get like 20mm i saw someone had those with the studs on it
Old Jan 27, 2009 | 09:58 PM
.:Made in OC:.'s Avatar
From what i know, all oem studs are not recommend over 5mm spacers. 5mm is already sketchy...
Old Jan 27, 2009 | 10:00 PM
NTCustoms's Avatar
okay to clarify things up, you can't run more than a 5mm spacer on stock studs. to do so is just plain stupid. it's no wonder your studs broke, because after the spacer + the wheel you'd probably be left with less than 5mm of stud left. the RSX stock stud is 25mm from the brake rotor hub.
Old Jan 27, 2009 | 10:01 PM
ok well i will be getting spacers with the studs on them already
Old Jan 27, 2009 | 10:21 PM
NTCustoms's Avatar
keep in mind that since its only a 10mm spacer your wheel must have the notches in the wheel hub to keep from hitting the stock studs....an example of a wheel that will work with integrated stud spacers are Rotas, and an example of a wheel that won't work with them are Work wheels.
Old Jan 28, 2009 | 04:30 AM
JamesL's Avatar
I wouldn't run above a 3mm spacer on the stock studs. Frankly, there isn't any reason to run a spacer without extended studs (except for the 25mm bolt on applications). Be safe about it.
Old Jan 28, 2009 | 09:10 AM
WhiteOnRice's Avatar
Why do you want the 10mm spacers in the first place?
Old Jan 28, 2009 | 11:07 AM
josh's ep3's Avatar
Function > Form
I'm gonna get the studs. I wanted to get spacers for the front because I'm hoping to hit the track soon and I hear a wider front stance for FF cars helps with steering response. I also like a wider stance anyway. The wheels I have right now are +25 offset and I love the way the look and they're nice and flush. The wheels I'll be tracking with are +35 offset so a 10mm spacer will widen the stance as if I was running a +25 wheel again. I might even do a bigger spacer so I'll be getting the studs anyway, plus they'll be better for the abuse the track will be putting on stock studs.
rexload
May 27, 2015 07:30 PM
Chris93Si
Mar 12, 2005 03:22 PM
9seccivicsi
Jan 7, 2004 05:55 PM
Cheap Bastard
Jan 29, 2003 12:36 PM
ILOVEGIRLS
Apr 10, 2002 05:17 AM
