hood dampers?
Old Jan 26, 2009 | 12:05 PM
sfcd5's Avatar
Default hood dampers?
hi i have a 94 accord and i was wondering if there are any hood dampers from other cars that i can use on my car? dont want aftermarket ones. looking for ones i can find at the junkyard.
thnx
Old Jan 26, 2009 | 12:26 PM
GhostAccord's Avatar
Default Re: hood dampers?
What do you mean by hood damper? Do you mean like a turbo vent or an air intake /hood scoop?
There are probably a few out there that will fit. early year WRX comes to mind. It's whether or not they will look good. And how much metal cutting & fiberglass work your up to too doing to get it to look good. Most of the newer style scoops are built into the hood with just a grill insert that can be removed. That sort of ram air scoop won't work without a bit of hood modification.
Old Jan 26, 2009 | 12:28 PM
extralargenog's Avatar
thnx
you mean hood struts yes (that keep the hood open???)
Old Jan 26, 2009 | 12:32 PM
redbull-1's Avatar
Check some of the Accord V6, which had hood struts.
Old Jan 26, 2009 | 12:47 PM
Oh and here I was thinking that there may actually be a thread containing some DIY or requiring something more than what you could find in a 30 second google search or 10 minutes at the junk yard.
Any strut that is rated for the same weight will work.....Probably get some good strong ones off an early 90's domestic. Oldsmobile, Ford, Chev you name it they will have hood struts that will throw up your hood. I know for a fact that the 94 Oldsmobile Achieva has a good strong pair.
Old Jan 26, 2009 | 01:08 PM
sfcd5's Avatar
yes thnx sorry about that.
Old Jan 26, 2009 | 05:10 PM
doubleRdazz's Avatar
acura legend ones will work
get the brackets with them and you can bolt them to one of the fender bolts and the other side you will drill into the upper part of the hood hinge
pretty easy to do
ericstambaugh07
Jun 18, 2007 06:00 AM
ViperRedCRX
23
Jun 6, 2003 10:45 AM
iam7head
Aug 23, 2002 07:27 PM
JSpecwest
Nov 17, 2001 10:40 PM
