I need some top hats
I have some tanabe Coil overs: http://www.jazzproparts.com/product_p/tss002x.htm to be exact, and Im looking to get some extended top hats. Would these http://www.ground-control-store.com/...p/II=647/CA=97 do the trick, or do I need to go another route?
thanks!
thanks!
Oh :S I had a friend tell me that even though it says that, they should work with mine. Does Tanabe make a set? I couldnt seem to find them if they do exist
The GC extended upper mounts should work fine with any 2.5" ID spring.
But, aren't those fixed stroke shocks? If so, all an extended upper mount would do is further limit droop, and provide no benefit.
Perhaps I'm misusing the term.
Your typical Koni would qualify as "non-fixed". Lower the car on a GC sleeve, and the shock is now at a different location, in terms of the piston relative to the body (more droop, less bump available).
Many of the "full coilovers" adjust height by moving the shock body itself (what I am calling "fixed stroke"). The shock preserves the same bump and droop lengths, regardless of ride height. These are the suspension that adjust spring preload separately from ride height.
Can someone else confirm or refute my use of the terminology here? I'd like to sound like I know what I'm talking about...
I'm not seeing how an extended top hat will benefit a 1 piece coilover setup, unless the coilovers were designed that way in the first place. Top hats are made for GC sleeves because chances are the off-the-shelf shock being used isn't designed to work very well when lowering the car as much as most people do.
It just seems to me that if the shocks in the tanabe setup would benefit from an extended tophat, they would've designed them that way.
I dunno maybe I'm way off here.
If your really low you can use the extended top hats to move the bumpstop up higher into the car. But if your car has an average drop and still hits the bumpstops you need stiffer springs.
On my DA integra I had diy extended top hats because with my koni/gc the car was sitting on the bumpstops. That was with 3/8" thick bumpstops the GC sleeves all the way down and the konis on the bottom perch.
civicduty13
Suspension & Brakes
Feb 13, 2009 10:24 PM
