what is safe boost for a stock gsr?
Old Jan 25, 2009 | 11:14 PM
crazykamper's Avatar
Default what is safe boost for a stock gsr?
i need to know how high i can boost my car on a stock motor. please let me know asap
Old Jan 25, 2009 | 11:27 PM
g3Gsr443's Avatar
Default Re: what is safe boost for a stock gsr?
around/under 8lbs i think. someone in the forced induction forum would know better than me though...
Old Jan 25, 2009 | 11:34 PM
jdm602's Avatar
wrong section but since im here might as well tell you that safe is a range. safe will be based on your setup. but so far my friends taken his bone stock gsr to 21 psi.
Old Jan 26, 2009 | 12:09 AM
my_hidden_romance's Avatar
i ran 9 psi.. im running 12 now.. nothings happened..
Old Jan 26, 2009 | 04:10 AM
HonkeyDong's Avatar
There isn't really a safe level, it depends on the health of your motor.
Old Jan 26, 2009 | 06:07 AM
neardon's Avatar
I'm a Jackass
I think you should be asking how much horsepower can a GSR handle before my stock internals snap.
Old Jan 26, 2009 | 06:27 AM
96 GSR-T's Avatar
Boost pressure is irrelevant, hp is what is relevant. You will be safe under 400whp depending on the condition of your engine.
Old Jan 26, 2009 | 07:24 AM
GuusMeij's Avatar
I have the same question.
But i have heart that not HP will kill an engine, but torque.
What is a safe number of torque with a gsr?? (around 250?)
Guus
Old Jan 26, 2009 | 07:40 AM
beutler09's Avatar
as little of advice as this is it is very true!
honestly i my self wouldnt do more than 8 psi. and really i would of done a few supporting mods first to help make your car healthyer and stronger IMO
Old Jan 26, 2009 | 07:57 AM
slammedem1's Avatar
300-350 WITH A LEGIT TUNE would be my guess.. ill be running about that much but with forged rods and pistons and all arp bolts..
Old Jan 26, 2009 | 08:27 AM
BrothaSit's Avatar
i run 7lb on mine with a downloaded map still running strong for 2 years daily driven
Old Jan 26, 2009 | 08:56 AM
spoon18's Avatar
300 - 400 get a good tune and hope for the best lol
Old Jan 26, 2009 | 08:59 AM
cluelessmale's Avatar
mine survived a 25psi+(boost gauge only goes till 25) for 4 gears, then I realized that I had the waste gate hooked up wrong
Old Jan 26, 2009 | 09:14 AM
spoon18's Avatar
haha thats funny
Old Jan 26, 2009 | 10:51 AM
Glove's Avatar
on a stock gsr,
use 10 psi, same as stock map sensor.
Old Jan 26, 2009 | 10:53 AM
jdm602's Avatar
theres people making over 400 for a long time now. but in the 300 range is pretty safe.
Old Jan 26, 2009 | 11:00 AM
Schister66's Avatar
Man U FTW
Wow...i'm surprised this thread made it as long as it did.
As with all turbo setups, PSI is irrelevant. Each turbo makes a different amount of power at a different Pressure Ratio. On your stock GSR on pump gas, you're limited to around 300-325whp safely. With higher octane fuels like E85 or race gas, you can make more; however, with added power comes added stress on internal parts.
boostedekhatch1
Jun 7, 2010 05:16 AM
WillieB
Jul 2, 2006 10:09 PM
integralsdriver29
Jan 20, 2005 07:59 PM
mozez
Jan 13, 2004 08:48 PM
Black-Stang
Jul 7, 2003 04:52 AM
