Power Steering removal ek/em
Old Jan 25, 2009 | 08:51 PM
Mr. Em1's Avatar
Default Power Steering removal ek/em
hey guys i know some of you high hp guys needed to get rid of power steering to run you big turbos in your ek's. i haven't really found any solid info since the Honda tech search sucks major ***** i cant find any old posts. any of you guys using an fittings and stainless lines to loop your racks? I'm looking to get the part numbers or sizes of the fittings/ (i suppose NPT-> an) for my steering rack (99 civic si) i know that these racks differ from the 92-95 civics and Integras racks.
Also what is your guys opinion on running a reservoir i have heard of people having issues of built up pressure blowing the caps off of them and fluid going everywhere. Also what kind of fluid should i fill up my rack with?
Old Jan 25, 2009 | 09:02 PM
ShawnR's Avatar
Default Re: Power Steering removal ek/em
on my si i bought a manual rack off a 96 cx civic everything is the same execpt the link between the steering column and the rack itself u need the one off a cx as well.. its funny u asked this cuase a long time ago when i was doing it to mine i couldnt find any info on it eather so i just bought the rack and it fit
Old Jan 25, 2009 | 09:05 PM
Mr. Em1's Avatar
lol i did ask this a while ago you are right, i dont wanna change the rack id rather have the benefit of a looped ps steering rack because the ratio is much better than one that is already manual. quick question
Do you need to drop/ lower the rack to uninstall/ install new fuel lines? im runnin -10 feed and -6 return.
Old Jan 25, 2009 | 09:16 PM
ShawnR's Avatar
i droped the subframe on mine u might be able to get away with not droping it.
Old Jan 25, 2009 | 09:25 PM
Mr. Em1's Avatar
hmm well somebody has to have looped an ex or si rack. SOMEONE
Mr. Em1's Avatar
Or at least know the sizes that the oem fittings are and then i can go about converting them to AN.
Old Jan 25, 2009 | 09:29 PM
98civicswapped's Avatar
yea i did the same on my 98 ex i just changed the whole rack. I didnt drop the subframe i just had to take it out on the passenger side. I guess i need the link now
Old Jan 25, 2009 | 09:32 PM
Mr. Em1's Avatar
lol damn it
Old Jan 26, 2009 | 05:09 AM
vtekthis's Avatar
looped mine at the rack, been racing it for 4+ years like that
Old Jan 26, 2009 | 05:30 AM
rota92
Guest
Posts: n/a
Take the fittings out and see what thread pitch they are, then order your stuff. Honda may be able to tell you as well.
Old Jan 26, 2009 | 05:58 AM
Mr. Em1's Avatar
Lol I took at the bolts and have no idea where the hell they went. I guess I'm gonna have to find them
Old Jan 26, 2009 | 06:01 AM
rota92
Guest
Posts: n/a
Or find that kit some guy makes and see what he is using, or see what thread size it is by measuring the ID and going to a hardware store and checking what is close? lol That's what I would do, or run a tap down it if you have something around that size.
Old Jan 26, 2009 | 06:37 AM
96 GSR-T's Avatar
I used the Stealthmode kit, not sure if they sell one for your car, by the time I got done searching for all the thread sizes etc it was easier to just spend under $100 and be done with it.
I dont use a resevoir I just left the line open and only put a little fluid in it, I can jack my car up and turn the wheel as fast as I can and nothing squirts out
Old Jan 26, 2009 | 02:14 PM
Mr. Em1's Avatar
so the system is not closed? hmm i wonder if the fittings are the same, they are probably are the same size but just a different amount
Old Jan 26, 2009 | 03:03 PM
96 GSR-T's Avatar
Yea I left mine open, I searched for a little while for a resevoir and couldnt find one so I just left it, steers really nice going down the road.
I acutally forgot to remove the extra fluid and when I had my car jacked up I turned the wheel and the fluid shot out and hit my ceiling in the garage, after that I just put a little bit back in and its been fine.
Old Jan 26, 2009 | 03:10 PM
a1320addict's Avatar
One of the guy's on here, "Padawan" I believe, has a full kit available with reservoir. I've used it, worked well.
I've just been removing the factory hard lines, cutting the flare and removing the threaded sleeve, weld each shut, and just top off the rack, and use the OEM threaded sleeves as plugs.
Old Jan 26, 2009 | 03:34 PM
Mr. Em1's Avatar
word that works too. i need to learn how to weld. lol
testify
Suspension & Brakes
Jun 13, 2013 08:09 PM
Mr. Em1
Jan 26, 2009 02:12 PM
MrTodd
Apr 10, 2005 02:59 AM
Jap Ek9
Mar 22, 2004 03:11 PM
neutron91
Aug 11, 2003 10:48 AM
