B16a Problems..
OK so here goes my story:
I own a b16a crx , due to engine/transmission complications i decided to swap in a mintier b16a motor/J1 trans. Just recently i finished my swap, checked EVERYTHING and fired her up.. everything seemed normal, i checked everything over countless times, and got my crx ready. When i drove it out of my block, it felt like the same day i got the car, everything in normal working condition etc, but than..
The throttle response was weird, now.. i was not just reving my engine trying to get into gear and move, i was moving. As i went to shift from 1st - 2nd everything was fine, but when i shifted from 2nd - 3rd my rpms dropped, almost stalled and i couldn't get into gear for my car to move. Even though i went into 3rd gear, my car would just rev like it was in neutral, i lightly applied pressure to the gas pedal and got nothing, kept trying untill i finally got the car to move and park it.
I didn't want to stall the car on purpose but then i tried it, i put it into first (parked) tried to launch at 1500 rpms, and got nothing.. so i let off the clutch pedal as i was still at 1500 rpms, my car didn't stall.
I played around with the clutch cable, and throttle cable but still couldn't launch, i checked the linkage/shifter and everything seemed up to par, but my car STILL will not launch/move.
So basically what i'm asking out of honda-tech is:
What should i check for?
Has anyone experienced this before? if so.. what did you do?
What do you think it is?
Thanks!
Thanks!
Ok well i guess i have one lonely case here.. I figured it was the wrong type of VSS in my transmission, my axle was not in place correctly therefore not spinning the wheels, Now it seems like i have some kind of shaft (gold) inside the shaft where the axle goes into the transmission for the VSS, only problem is.. it won't move! any help here guys?
